Nav v time
- Been liked: 476 times
Re: Nav v time
Is this thread from BMWMOA any help, https://forums.bmwmoa.org/showthread.ph ... -Year-2000
- Bike Model and Year: 2016 LC
- Been liked: 1 time
Re: Nav v time
Yes, mine currently shows 2 Apr 2000. I don’t think it affects the nav function of the unit but will follow the topic in the event of a fix from Garmin.
Re: Nav v time
Tried my Nav V yesterday on my 2016 RT & date/time were correct on the bike after a couple of minutes till GPS connected to sat's.
- Sprintgull
Re: Nav v time
bighopper wrote: Tried my Nav V yesterday on my 2016 RT & date/time were correct on the bike after a couple of minutes till GPS connected to sat's.
That's what my Nav 6 did too. I had the Nav 5 before that and don't remember ever having to adjust the time so it must grab that info once it has found satellites. I might be wrong, but I think the bike's clock feeds from that too?
Re: Nav v time
This is distinctly odd. A GPS needs a very precise time in order to work out where it is. It detects the time lags from the various satellites to work out how far it is from each one. So even an error of one second would cause a miscalculation of many miles. An error of 19 years would put you way beyond Proxima Centauri!
DW
- Been liked: 25 times
Re: Nav v time
Dee Dub wrote: This is distinctly odd. A GPS needs a very precise time in order to work out where it is. It detects the time lags from the various satellites to work out how far it is from each one. So even an error of one second would cause a miscalculation of many miles. An error of 19 years would put you way beyond Proxima Centauri!
It is certainly bl**dy annoying that the time is indeed correct (apart from GMT/BST issue) but the date is wrong. The software has counted 1024 weeks from some fixed datum and rolled back to week 0 (or 1) to calculate date.
Re: Nav v time
If you phone Garmin's support and tell them the date is out they will put you on the mailing list for when a update is available, as for the time untick auto box and manual set for the time being
Re: Nav v time
Much, much easier to do on their website. No holding, no computer voices. Pete wrote: If you phone Garmin's support and tell them the date is out they will put you on the mailing list for when a update is available, as for the time untick auto box and manual set for the time being
Go to https://support.garmin.com/en-US/?produ ... pics. Enter your info and you are on the list for notification.
Re: Nav v time
Think that is just a holding comment, I would be surprised if they mail you if a fix is ready. I phoned up and spoke to someone, they said they were aware of the problem, they didn't ask me for any details or the serial number of the Nav, so how will they know to mail me? There are 1000's now with this issue all over Europe and the US. Some in the US have had their Vs replaced, which kind of indicates its not a software fix, hope I'm wrong on that one, because if its hardware we will be stuffed in the UK. Luckily the V I have is off another bike and my main Nav is a VI which is fine.
