Trickle charging
Trickle charging
I just purchased a 2013 R1200RT. This replaced my 1996 R1100RT. Since I only use the bike on weekends I keep the battery charged by using a Battery Tender. I plug it into the accessory port. On the old r1100 it worked great. On my 2013 r1200rt it starts to flash red after a short time which means it isn't charging. Any idea why? Wonder if anyone else had or has that problem. Thanks.
- Been liked: 237 times
Re: Trickle charging
Looks like CAN-bus was introduced in 2004, https://motorcycleinfo.co.uk/bmw-r1200g ... indexc97d/
Is the battery tender/charger CAN-bus compatible.
bargood wrote: I just purchased a 2013 R1200RT. This replaced my 1996 R1100RT. Since I only use the bike on weekends I keep the battery charged by using a Battery Tender. I plug it into the accessory port. On the old r1100 it worked great. On my 2013 r1200rt it starts to flash red after a short time which means it isn't charging. Any idea why? Wonder if anyone else had or has that problem. Thanks.
You need a specialist CAMBUS charger, lastest Optimates do this but older ones do not (although even the latest ones need to be set correctly),but I had problems with mine so ended up shelling out for a proper BMW one which works faultlessly
Which battery tender/charger have you got, can it be hardwired to the battery with an appropriate lead.
I use a 2004 Datatool charger via a lead bolted to the battery.
Either connect a trickle charger direct to the battery or get the canbus version and use the auxiliary socket.
Battery Charger thread, viewtopic.php?t=9
Accumate 6V/12V Battery Charger, https://www.mdsbattery.co.uk/accumate-6 ... gJ1pvD_BwE
BMW Motorrad Battery Charger (UK plug), https://bmw.europe-moto.com/gb/motorcyc ... gInOvD_BwE
BMW trickle charger is the best bit of kit to keep your bike battery fully charged all of the time especially during long winter and Covid19 lockdown days/weeks.
Frank123 wrote: BMW trickle charger is the best bit of kit to keep your bike battery fully charged all of the time especially during long winter and Covid19 lockdown days/weeks.
Agree its brilliant, plug in the auxiliary socket and a warning sign on the Bike cover reminding me its connected and you can forget it.
https://www.nippynormans.com/k1600gtgtlsportbaggerga/optimate-44-bmw-can-bus-goldline-dual-charger
I would recommend plugging a pigtail directly into the battery and using the charger in standard mode. Charging via CanBus for example via an Opitmate you are only using a fraction of the feature on the charger.
NLC wrote: I would recommend plugging a pigtail directly into the battery and using the charger in standard mode. Charging via CanBus for example via an Opitmate you are only using a fraction of the feature on the charger.
That's why I use a BMW charger, it talks to the bike and the two work together to keep the battery in the best possible condition.
- Has liked: 35 times
- Been liked: 47 times
Unless the battery has been neglected and is very flat (sulphated), the Optimate 4 (dual CAN-bus version) should work just fine through the accessory socket.
This program is designed for charging, testing and long term maintenance of batteries mounted in vehicles fitted with CAN-bus.
Optimate 4, Instructions for use, https://static1.squarespace.com/static/ ... ctions.pdf
I’d rather take the money I saved and buy my mates a few rounds. BMW charges £68 for the special oil. At the end of the day it is oil. The “special” charger is BMW profiting from white labelling someone else’s product.PeteM wrote:
David I have spoken to Optimate about this. Answer from them is to not use the Canbus. Many of the Optimate functions are disabled in the Canbus mode.David. wrote: Unless the battery has been neglected and is very flat (sulphated), the Optimate 4 (dual CAN-bus version) should work just fine through the accessory socket.
