Throttle Gizmo
Beagle
Throttle Gizmo
Post by Beagle »
Got one of these and tried it yesterday. It felt good at first but after a while I discovered it does nothing to combat fingers going numb and it actually makes throttle movement erratic.
Decided to remove it and have ordered some foam grips.
gogs01
Re: Throttle Gizmo
Post by gogs01 »
What is a throttle gizmo ?
Beagle
Re: Throttle Gizmo
Post by Beagle »
gogs01 wrote: What is a throttle gizmo ?
Apologies copy and paste didnt work
Been liked: 251 times
Re: Throttle Gizmo
What causes fingers to go numb.
Has liked: 36 times
Been liked: 52 times
Re: Throttle Gizmo
David. wrote: What causes fingers to go numb.
A vice works pretty well.
Has liked: 36 times
Re: Throttle Gizmo
Beagle wrote: Got one of these and tried it yesterday. It felt good at first but after a while I discovered it does nothing to combat fingers going numb and it actually makes throttle movement erratic.
I've got "grip puppies" on both my RT and GS and they help me with the bikes vibrations.
Beagle
Re: Throttle Gizmo
Post by Beagle »
Its not the vibration but the pressure on the fingers reducing blood supply by the glove and also gripping the throttle grip. Doesn't happen on the left hand. Gloves have plenty of room so not size.
Re: Throttle Gizmo
Cruise control works a treat.
Has liked: 36 times
Re: Throttle Gizmo
Beagle wrote: Its not the vibration but the pressure on the fingers reducing blood supply by the glove and also gripping the throttle grip. Doesn't happen on the left hand. Gloves have plenty of room so not size.
Carpal tunnel surgery?
Beagle
Re: Throttle Gizmo
Post by Beagle »
David. wrote: Cruise control works a treat.
Not round country lanes.
Beagle
Re: Throttle Gizmo
Post by Beagle »
Nothing to do with the wrist.
Has liked: 36 times
Re: Throttle Gizmo
Beagle wrote:
I can see your anatomy knowledge continues to be lacking.
Welcome to the list.
hammo
Been liked: 17 times
Re: Throttle Gizmo
Post by hammo »
I have the throttle rocker as well i find it works good if your fingers start to get stiff , dunno about going numb though , cold ? circulation ?
PeteM
Re: Throttle Gizmo
Post by PeteM »
I used one of those on my Triumph Sprint, only found it fully useful on motorways and other constant speed roads, now use cruise control in those situations. I think if you are trying to use it for country lanes you are on a hiding to nothing but it is still useful as when you come into a village and you want to travel through at a constant sensible speed you can stretch your fingers out (which incidentally makes them closer to the brake for when the random child runs out) thereby giving you some relief.
Beagle
Re: Throttle Gizmo
Post by Beagle »
hammo wrote: I have the throttle rocker as well i find it works good if your fingers start to get stiff , dunno about going numb though , cold ? circulation ?
I manage to play my guitar fingerstyle. I think its something to do with gripping the small in circumference twist grip with gloves on. Its this that restricts circulation in the fingers. Maybe the extra foam grips Ive ordered will help.
