Retro fits
mondeoman
Retro fits
Post by mondeoman »
Does anyone know if the corona lights (circular angel eyes) and the high level top box brake light can be retro fitted to a 1650 RT LE ?  I've just purchased a 7 month old one with only 600 miles, it has the top box with central locking and interior light but lacks the actual hi'level brake light. The coronas that circle the twin hi' beam lights are also not there, I wrongly thought that  LE s' had them as standard, turns out they are optional.
I've inquired with a Motorrad dealer and awaiting an answer currently.
Mondeoman
gogs01
Re: Retro fits
Post by gogs01 »
I think you'll find the high level brake light is a straightforward retro-fit, the corona lights probably not !
Been liked: 280 times
Re: Retro fits
Looks like the Daytime running lights might only be available as part of the "Dynamic package" factory fit option.
https://www.bmw-motorrad.co.uk/en/model ... legant-one
Re: Retro fits
As posted by gogs01, the top case additional brake light can be retro fitted.
This video shows how to do it, https://www.youtube.com/watch?v=BAz_PSB0ybM
and here is the part required, https://www.online-parts.co.uk/bmw-bike ... nth=01#sub
Arek
Has liked: 3 times
Contact:
Re: Retro fits
Post by Arek »
Top Box brake light it is 10 minutes job. Very easy to retrofit. Actually plug and play really. As all the wiring is already in the OEM top box.
mondeoman
Re: Retro fits
Post by mondeoman »
Thanks to all that replied, Extra thanks to David for the vid/parts #,  I've now heard from Motorrad re' the brake light , total price to supply and fit is £154,  David, if I'm reading your part list info correctly, the brake light kit alone is about the same price as the Motorrad part and fitting price indicating Motorrad would fit it effectively free ?
Mondeoman
Re: Retro fits
At over £150 for the part which takes 10 mins to fit, it would be taking the pi$$ to charge for fitting.
Especially if you bought the bike from the same BMW dealer.
mondeoman
Re: Retro fits
Post by mondeoman »
David. wrote: At over £150 for the part which takes 10 mins to fit, it would be taking the pi$$ to charge for fitting.
You're right David, I've just pulled it apart and sure enough, 10 mins to do, I'll order the kit.
Re' the "corona"  lights,  having had 2 RT's with them I realised I would need to have the switch button on the left to access the "settings" menu and DRL menu plus the internal wiring in that switch cluster plus the software in the ECU to make it work, maybe the wiring is already in the switch cluster and maybe the software is already in the ECU, who knows, motorrad have yet to advise me .
Mondeoman
Re: Retro fits
mondeoman wrote:I'll order the kit.
I always ask & usually get a discount on parts from my local BMW dealer.
Re: Retro fits
mondeoman wrote:Re' the "corona" lights, who knows, motorrad have yet to advise me.
You might even need a different headlight, two are listed, Headlight I or II.
mondeoman
Re: Retro fits
Post by mondeoman »
Good grief ! think I'll just forget that one. just ordered the hi' level brake light kit, small disc' with free delivery, only 3 in the UK apparently.
Mondeoman
