Just finished installing the Innovv K2 on a 1250RT, thought I would upload some pics in case it is of any use to someone.
Front camera is bolted to the vent guide on the bottom of the headlight (bracket fits nicely in here), rear camera is bolted into the rear luggage carrier. DVR is fitted into the right side glove box, this was added to the bike and the cables are sleeved to allow the unit to be pulled out easily for access. The unit does occupy most of the compartment but there is still space in there for a few other small pieces. The images from the cameras are perfect.
The power converter is attached to the tank with a velcro pad and goes off to the battery while the yellow pilot is fitted into the power socket thorough a homemade Y adapter.
The GPS module is currently behind the speaker but seems to only work occasionaly so I am looking for an alternative.
[attach=1][attach=2][attach=3][attach=4][attach=5][attach=6]
As for the package itself, it seems a very good quality unit, my only complaint is the connections being on more than one side of the unit, makes a neat installation quite difficult.
Innovv K2 Installation
Re: Innovv K2 Installation
Thanks for that.
Did you drill through the rear rack to fix the bracket ?
Thanks for the photos Graham, like where you've put the cameras, I'll fit my DV688 now I have an idea where and how to fit it.
