Horning make a cable to harness the mirror to the bike if it comes away from its mount by collision or shock, such as a pothole.
According to the description it covers ‘05-‘13, are they necessary for the LC models as well?
Mirror retention cables
- Has liked: 1 time
- Been liked: 11 times
Re: Mirror retention cables
OR, just use a zip-tie. Just make sure it's loose enough to still pop the mirror out a bit to cut the tie if you need to remove the mirror for any reason.
- Been liked: 477 times
This thread on BMWMOA, https://forums.bmwmoa.org/showthread.ph ... r-fell-off also suggests that on a Wethead,
"the mirrors are supposed to be tethered to the bike so they can't fall to the ground".
- Steve398
- Has liked: 474 times
- Been liked: 405 times
It seems the mirrors may be but the covers aren’t, I knocked the n/s one off when I caught it with my elbow in the garage yesterday.
- Has liked: 1 time
- Been liked: 6 times
Get a bit of wire and 2 blue ring crimps, crimp them up and you have your tether. Strong enough to hold mirrors anyway.
- Steve398
- Has liked: 1 time
Gotta say again: a couple of zip ties and you're done. Quick, simple and cheap. The assembly is not very heavy. With any of the DIY tethers proposed here, you can't make it too long or loose or when it pops off it will hang and bang your faring at motorway speeds; too short and it'll be difficult to snip the zip if you need to remove the mirror assembly.
