Is this aftermarket battery OK? 2014 R1200RT
Kunkies
Post by Kunkies »
My second battery is beginning to show signs of losing its charge.  Purchased a XTreme 12V AGM XTAX20CH-BS 12V 18Ah replacement battery which is 18Ah versus the OEM 16Ah yet exact same physical size.  Is that OK??
https://www.batteriesplus.com/productdetails/battery/motorcycle/bmw/r1200rt/1200cc/2014/cyla20chbsxta
Bike:  2014 R1200RT
Accessories added that draw power:  Denali CANSmart CANBus Controller, Denali DR1's driving lights x2, Denali DRL Accessory lights amber x2, Denali B6 dual rear brake lights, I ride year round; so using the CanBus 12V DIN maximum draw with heated gear is 9.2amps.
Thanks in advance for your input, feedback.
-Bob
-Bob
Boxflyer
Re: Is this aftermarket battery OK? 2014 R1200RT
Post by Boxflyer »
Deleted
ca1ic0cat
Post by ca1ic0cat »
Very well done answer, kudos to you.
