A quick question for the home servicing guys. On the new Hayes front callipers does anyone know the size of the Torx bit required to unscrew the pad retaining pins? Thanks!
John
Hayes calliper pad pin head size
- Been liked: 241 times
Re: Hayes calliper pad pin head size
From what I can see of the Hayes calipers fitted to a GS, https://advrider.com/f/threads/itemized ... c.1468607/ the pad pins require an E8 E-Torx, (female socket), could be the same for the RT. (A part no. check seems to confirm that the pad pin is the same for both the GS & RT).
GS
RT
GS
RT
- John Cockburn
Cheers David, all that ties in with the checking I had already done.
Thanks again,
John
Thanks again,
John
John
