My 1st post newbie here- I just bought a 2008 R1200RT police that needs new tires immediately. The font wheel is dented but still holds air.
I also have a lot of spare parts from a 2003 Triumph 955i Daytona including a front wheel. Both wheels are 17x3.5 inch with dual 320mm rotors.
Will the Triumph wheel work on the BMW or is there something that's incompatible?
Thanks for any help
Triumph front wheel on BMW
- Been liked: 243 times
Re: Triumph front wheel on BMW
Could it be repaired, Repairing damaged wheels | MCN (motorcyclenews.com)motorradical wrote:The front wheel is dented but still holds air.
"A good rule of thumb for working out whether a wheel can be repaired is if the tyre is still inflated on the wheel."
Is the speedo drive off the front wheel on the Triumph.motorradical wrote:Will the Triumph wheel work on the BMW or is there something that's incompatible.
- Been liked: 14 times
David. wrote: Is the speedo drive off the front wheel on the Triumph.
...not to mention the fittings for ABS ring.
As David says, if the wheel is really bad, get it straightened or purchase off a breaker such as Motorworks. Do put the new tyres on before you have a whoopsie!
Regards,
John
P.S. What continent are you on?
- Has liked: 353 times
- Been liked: 99 times
Also, you will need axle spacers made up. Hate to think your insurance would say if you had a claim.
