fairing power socket
Has liked: 1440 times
Been liked: 409 times
Does anyone know the max watts or amps that the power socket can cope with before tripping the Canbus?
Been liked: 478 times
Re: fairing power socket
10A
Has liked: 229 times
Been liked: 105 times
10 amps between both sockets on 2014 on. Believe only 5 for the old models.
Cheers for the replies. That may be a bit low for heated clothes.
Had a recalculation and my jacket only draws 1.5 amps. So i should be fine. With my maths now working correctly with 5 amps i could run a pair of 40 wat spots with ease.
Thank you, David i can see it's rated at 10 amps for a 2007 model.
Has liked: 101 times
Been liked: 232 times
Doctor T wrote: Had a recalculation and my jacket only draws 1.5 amps. So i should be fine. With my maths now working correctly with 5 amps i could run a pair of 40 wat spots with ease.
Wow! that's low, what jacket is that? my Gerbing jacket draws 6.4 amps, gloves 2.2 amps (per pair), socks 2.2 amps (per pair) pants are 4 amps and vest is 5.4 amps.
It's a Keis V501RP Pro. It's not a full jacket but a body warmer. I find as long as my torso is warm I've no need for heated sleeves. I've also just bought a pair of Keis G701 gloves but they draw more at 1.6amp.
David and Sally
Has liked: 13 times
Been liked: 16 times
Post by David and Sally »
simbo wrote:
Wow! that's low, what jacket is that? my Gerbing jacket draws 6.4 amps, gloves 2.2 amps (per pair),socks 2.2 amps (per pair) pants are 4 amps and vest is 5.4 amps.
Hell Bells. ^-^  I bet your mates get to the coffee stop before you have even finished plugging in. !!
Has liked: 478 times
If you’re out in it all day there’s absolutely no pleasure in being cold. It’s not just about comfort as it also adversely affects your riding performance.
Oh, the blissful pleasure of a heated jacket on a cold day! 😍
David and Sally
Has liked: 13 times
I have a heated waistcoat as well as using the heated seat and grips. Hate riding in the cold and damp. I agree about performance.
As long as my Kidneys and chest are warm i don't mind how cold it is
