How to remove the seat panels?
- Has liked: 1695 times
- Been liked: 549 times
Evening all. Fitting rear crash bars but i can not find out how to remove the seat panels. I have found 2 bolts that allow the front edge to move but i need more asses to the frame bars. Are there any videos on YT?. Can you help?.
- Been liked: 506 times
Re: How to remove the seat panels?
Looking at this photo, the rear carrier needs to be removed to access a screw underneath.
If it's the same as a Camhead, there is a screw near the rear socket which is accessed from under the seat.
There is also a screw on the underside (lower edge) rearwards of the footrest plate.
Cheers David. What a pain to fit rear crash bars. Anyhow, the front and rear are fitted now. The German only written instructions pushed my rusty German to the limits in places.
potatan
- Been liked: 5 times
Doctor T wrote: The German only written instructions pushed my rusty German to the limits in places.
Quick tip - Google Translate will convert printed text in other languages to English (for instance) using the camera and some sort of magic.
