I looked at a friends F850GA recently. It had a semi-circular 'plate' attached to the forks near the lower yolk (triple tree) presumably to reduce wind and/or road noise going up through the gap in front of the tank.
I want to make a similar system for my R1250RT but can't find out whether this is a standard OEM item or an after-market accessory. I took some photographs from underneath of what may have been a part number on the item but they weren't clear enough to read. My dealer doesn't have a F850GS/GSA in stock and wasn't able to help.
Any ideas of how to identify the item, please
Forks Mounted Wind/Noise Deflector
- bruce2000ltc
- Bike Model and Year: R1200RT 2013
- Has liked: 1 time
- Been liked: 5 times
Re: Forks Mounted Wind/Noise Deflector
It's called a fork protection plate. I found it on Max BMW's parts fiche.
Thanks Bruce & David, I'll check the fittings on my RT.
