head gasket
pencile
head gasket
Post by pencile »
I have a 2014 wet head 1200RT that I have a new head gasket to put on.  Is there a right or wrong side to put it on?  It has a BMW part marking on one side, other than that I can't find anything on if it makes any difference or not.
    thanks!!!!
Re: head gasket
Is the new head gasket between the cylinder and head or head and valve cover. If the latter, this video at 13:46 BMW R1200RT/GS wethead valve check procedure and spark plug change - YouTube shows what looks like the part marking facing towards the cylinder head when fitted to the valve cover.
pencile
Re: head gasket
Post by pencile »
its the actual cylinder to head gasket in question.
Re: head gasket
The cylinder head gaskets are packaged as left or right. Can the gasket actually be fitted with the part marking up or down.
Re: head gasket
I have never seen a symmetrical head gasket they normally can only be fitted one way
Re: head gasket
The two parts circled are different so it can only go one way
[attach=1]
2022-08-09 22 35 12.png (193.53 KiB) Viewed 795 times
pencile
Re: head gasket
Post by pencile »
That's the answer!!    Thanks so much guys!!!!!!!!!!!!!!!
