Greetings,
I have a 2016 1200 RT and installed P3 lights and followed the instructions from Skeene. Used switched power from under the seat, facing the bike I tapped into the fused power box, slightly on the right side of, using the red and green wire. Light is supposed to come off when power is off but stays on for 60 sec. Did I use the wrong wire?
Appreciate the help.
Switched Power
- Been liked: 476 times
Re: Switched Power
From what has been described, I don't think so. The red/green wire at the fuse box is a switched live.
As per the Skene instructions, "Note: power remains on to this connection point for 45-60 seconds after the ignition is turned off."
- Bike Model and Year: 2016 BMW RT1200
- Been liked: 1 time
Re: Switched Power
Thanks for the response. I must have missed that piece of instruction.
Thanks again,
Thanks again,
