2007 rear indicator bulbs
- Has liked: 1434 times
- Been liked: 406 times
Can anyone tell me if 581 BAU15 is the correct bulb for the above? Cheers
- Been liked: 477 times
Re: 2007 rear indicator bulbs
Has your bike got clear (white) or coloured (yellow) tail light indicator lens.
This will determine whether or not it needs a clear bulb or a coloured (yellow) bulb.
From what I can see, 581 is the correct bulb.
Looks like BAU15 is offset pins with a 15mm diameter.
They are clear, David
Looks like you need a BAU15S PY21W 581, https://xenons4u.co.uk/bau15s-py21w-581 ... bulbs.html
MAX BMW Part # 63 21 7 160 791
OEM part numbers:
BMW and Mini: 63217160791
Specifications & Features
Part numbers: BAU15S, PY21W, 581
Compatible cars:
K26 (R 900 RT, R 1200 RT) (11/2003 — 06/2014)
OEM part numbers:
Compatible cars:
Cheers David. Got them from Europarts this morning.
For future reference, which ones did you end up with, https://www.eurocarparts.com/search/581%20BAU15
I went with Osram Ultra Life 581 12V PY21W Amber Bulb - Twin Pack. £3.79
