Nearly there
Batfastard
Has liked: 4 times
Nearly there
Post by Batfastard »
Hi. Wee 2005 RT1200 i have been working on over Christmas is nearly the way i want it. Only issue i have is the side panniers seem very loose when fitted. Looking at this parts diagram i see the piece, number 23 is missing from my cases. Can anyone show me exactly where this bit goes. Thanks in advance :thumb:
Cornish_Camhead
Bike Model and Year: R1200RT 2012
Has liked: 3 times
Re: Nearly there
Post by Cornish_Camhead »
Isn't 23 the extending foot that moves to push onto the bottom bike pannier support when you close the handles down? I guess the panier would be loose without that bit :shock: sorry I don't have a picture but can sort one tomorrow with luck as the 05-09 same as 10-13 I think...
63 plate Camhead RT SE with NAV 5, 22l topbox, rear panniers with flat lids, RTP cooling fan, LED side lights, headlight protector, grip puppies, RTP engine bars. Stage 1 remap, sport end can, last of the air/oil cooled RT model.
Re: Nearly there
This video shows a side box being removed from the bike. When removed, the location of part #23 can be seen with the locking mechanism retracted.
Batfastard
Has liked: 4 times
Re: Nearly there
So it looks like it slides down past the locking mechanism. Will give that a try. Thanks
Re: Nearly there
I think the idea is that #23 can be purchased in different sizes to adjust the fit of the side box.
Batfastard
Has liked: 4 times
Re: Nearly there
Cheers David. Like a sort of shim?
Re: Nearly there
Batfastard wrote: Thu Mar 02, 2023 10:54 amLike a sort of shim.
Yes, I would agree with you. The original ones could be the thinnest.
Batfastard
Has liked: 4 times
Re: Nearly there
Cheers bud
