I have a '20 R1250RT, and when I change my suspension (preload) from "MAX" to "MIN" I hear a click; is this normal?
Thanks!
Hearing a click when changing suspension from MAX to MIN.
- Bike Model and Year: R1250RT, R100R
- Has liked: 7 times
- Been liked: 8 times
Re: Hearing a click when changing suspension from MAX to MIN.
No, its not normal.I had the same issue.It was repaired by Lukas at t tech suspension.Excellent work and great to deal with.
Well, the suspension works perfectly, nothing wrong with it, only hearing one click changing from MAX to MIN, wondering what causes it.
My '18 R1200RT LC did the same thing, also heared a click changing from 2 helmets to 1 helmet
- Been liked: 480 times
Could it be the suspension pre-load motor.
The motor was ok on mine.Luke repaired the mechanism when I had Tractive dampers fitted.It still worked ok but I didnt know for how long.Its fine now.
Emailed my BMW Motorrad dealer last week about my question, and the chief mechanic told me this "click" is normal, so that's fine with me.
