Basecamp Update
jjwill
Bike Model and Year: RT 2018 LC
Been liked: 5 times
Basecamp Update
Post by jjwill »
Garmin have released 4.7.5 update
Re: Basecamp Update
My version of Garmin BaseCamp is 4.7.3, what does the update mean/do.
Re: Basecamp Update
Minor update to BaseCamp, apparently to allow it to work with some newer devices, no change in functionality as there is no further development of BaseCamp
BaseCamp software version 4.7.5
as of March 27, 2023
Download (61.93 MB) here https://www8.garmin.com/support/downloa ... 5#Instruct
Notes:
System Requirements:
Windows 7 SP1 or later is required. Machines with earlier operating systems can use BaseCamp 4.2.5.
.NET framework 4.6 is required. A current version of .NET will be installed if needed.
1 GB of system memory is required, 2 GB of system memory is recommended when using BirdsEye Imagery or Garmin Custom Maps.
A video card that supports OpenGL version 1.3 or later is needed to enable the 3D view.
If you experience problems when interacting with the map views, please make sure that you have installed current video card drivers.
BaseCamp will recognize all MapSource products except BlueChart.
BaseCamp does not work with serial GPS devices.
Change History
Changes made from version 4.7.4 to 4.7.5:
Various stability and bug fixes
Re: Basecamp Update
Also note that this is for PC and not for Mac :)
Re: Basecamp Update
Thank you for the feedback. It looks like I should just leave well alone and continue with version 4.7.3.
Changes made from version 4.7.3 to 4.7.4:
Fixed zumo connection issue
I have no issues connecting my Zumo 660.
What are "stability and bug fixes".
Re: Basecamp Update
Its your choice David
I am a firm believer in updating to the latest all the time
Well once others have tested it first and not reported any issues :lol:
Re: Basecamp Update
sakm wrote: Fri Apr 14, 2023 4:50 pmIts your choice David.
I am a firm believer in updating to the latest all the time.
I don't do PC technology and am too anxious about making changes, wouldn't want to risk losing 100's of BaseCamp routes.
Re: Basecamp Update
David. wrote: Fri Apr 14, 2023 4:54 pm I don't do PC technology and am too anxious about making changes, wouldn't want to risk losing 100's of BaseCamp routes.
Just downloaded and installed it with no issues here!
You can back things up or export them to a safe place
Open basecamp select routes so its showing all routes
Click File and export
You can then keep them somewhere safe on a usb drive or something just in case anything ever did happen :)
Re: Basecamp Update
I have got a backup of BaseCamp and all my routes but will still leave well alone, thank you.
Re: Basecamp Update
I've also had problems with the required .NET framework 4.6 when trying to install Garmin Express updates. MY PC man contacted Garmin on my behalf and if I remember correctly, I'd need a new version of Windows installing on my PC to resolve the issue.
I have to uninstall, then reinstall Garmin Express when updates are available.
Re: Basecamp Update
What version of windows are you running?
Re: Basecamp Update
I think it's Windows 10 but don't even know how to check that.
Re: Basecamp Update
David. wrote: Fri Apr 14, 2023 6:48 pm I think it's Windows 10 but don't even know how to check that.
Nothing wrong with windows 10 if thats what you are running in fact I would stick to that than the latest windows 11
Has liked: 99 times
Been liked: 222 times
Re: Basecamp Update
Click on the windows button (bottom left) then click on the settings button. click on "system" on the left and scroll down to "about". click on that for all your computer information :thumb:
Re: Basecamp Update
Got it, Windows 10, thank you.
