Page 1 of 1
Rear shock removal
Posted: Tue Jun 06, 2023 9:38 am
by Panman40
Just wondering how big a job it is to remove an esa rear shock on an RT ?. I suppose all I'm looking to do is remove and grease up the bottom mount.
Re: Rear shock removal
Posted: Tue Jun 06, 2023 6:20 pm
by Steve398
I’m sure I saw a YouTube on it. From what Lucas at Ttech said the rear is far easier than the front.
Posted: Tue Jun 06, 2023 6:27 pm
by Panman40
I’ll take a look Steve 👌
Posted: Wed Jun 07, 2023 2:08 pm
by Panman40
Steve398 wrote: Tue Jun 06, 2023 6:20 pm I’m sure I saw a YouTube on it. From what Lucas at Ttech said the rear is far easier than the front.
Struggling to find a video for an lc Steve.
Posted: Wed Jun 07, 2023 6:03 pm
by Our Gee
Never had to remove a Rear ESA shock but I have removed the Front one on my 2013 Twin Cam and that was a pig due to the BMW Default practice of liberal "Thread Lock" on initial assembly. No doubt the Rear will have been be similarly assembled. What puzzles me is what part of the bottom mount do you think requires Grease. As far as I can recall the bottom mounting Pin locates through a Sleeve which is encapsulated in a Rubber Bush.( Used to call Silent Bloc Bush.) I would keep any Grease well away from this. Maybe others with more knowledge will be along.
Posted: Wed Jun 07, 2023 7:28 pm
by sakm
Does this help?
Posted: Thu Jun 08, 2023 4:52 am
by Panman40
Our Gee wrote: Wed Jun 07, 2023 6:03 pm Never had to remove a Rear ESA shock but I have removed the Front one on my 2013 Twin Cam and that was a pig due to the BMW Default practice of liberal "Thread Lock" on initial assembly. No doubt the Rear will have been be similarly assembled. What puzzles me is what part of the bottom mount do you think requires Grease. As far as I can recall the bottom mounting Pin locates through a Sleeve which is encapsulated in a Rubber Bush.( Used to call Silent Bloc Bush.) I would keep any Grease well away from this. Maybe others with more knowledge will be along.
I’ve no idea, I thought I’d heard talk on here somewhere of bottom shock mounts seizing up due to water and crud from the wheels saturating that area.
Posted: Thu Jun 08, 2023 4:53 am
by Panman40
sakm wrote: Wed Jun 07, 2023 7:28 pmDoes this help?
Thanks Stu, I’ll have a look on my phone, pdf won’t open on my iPad !.
Posted: Thu Jun 08, 2023 8:23 am
by burridge01
Panman40 wrote: Thu Jun 08, 2023 4:52 am I’ve no idea, I thought I’d heard talk on here somewhere of bottom shock mounts seizing up due to water and crud from the wheels saturating that area.
viewtopic.php?t=6675
