2011 R1200Rt No Start, No Crank
JustinWI
Bike Model and Year: 2011 R1200rt
Post by JustinWI »
Hi All,
My 2011 r1200rt is currently not starting or cranking. Battery is 1 year old, currently 12.7 volts. Just replaced start/kill switch as I though this was bad - but it did not fix the problem. Starter relay has 12v on terminal 5, nothing on terminal 3 when start switch is pressed. If i remove the relay from the bike and apply 12v to terminals 1 and 2 I can hear the relay click, and there is continuity between 3 and 5 - but this does not happen when relay is installed in bike and start switch is pressed. Do you think this is a bad relay, or is there a start up sequence/ safety check that happens before allowing power to pass to the relay?
Any help would be appreciated.
Thanks!
Justin
Has liked: 80 times
Been liked: 65 times
Re: 2011 R1200Rt No Start, No Crank
At 12.7 volts, your starter should be spinning. There is no real required starting sequence. I trust that you are in neutral? Have you dropped the bike recently? Are your battery terminals fully tight?
JustinWI
Post by JustinWI »
Yes the bike is in neutral (i've tried to start the bike with the side stand up and down). I have not dropped the bike. I checked the battery terminals and they are tight. I removed the terminals and left them off for an hour to see if that would maybe reset something in the computer.
Has liked: 620 times
Try side stand up with the clutch pulled in
The gear position sensor might not be picking up that it's in neutral
JustinWI
Post by JustinWI »
Good Morning,
I've tried with the side stand up and down with the clutch pulled in and unfortunately there is no change. I tried 1st gear, neutral, and 2nd gear.
