Removal of front abs speed sensor
Tom 2
Bike Model and Year: r1200rt 2011
Been liked: 5 times
Post by Tom 2 »
Hi all
Trying to remove the front sensor. Undone small screw. Try pushing and pulling but won’t budge. Is there a secret clip.
Any help would be appreciated
Tom
Has liked: 1433 times
Re: Removal of front abs speed sensor
This can get stuck a little. After removing the screw try to wiggle the sensor back and forth as pulling outwards. a quick spray of brake cleaner may help
Tom 2
Been liked: 5 times
Post by Tom 2 »
Thanks for the reply Doctor T
Already broke the plastic screw bit. Will try again and let you know how it went
Tom
Tom 2
Been liked: 5 times
Post by Tom 2 »
Ok quick update
That was some tight sensor. Good job I am replacing with a new one as I had to smash the thing to get it out.
I think the alloy coating has corroded a bit and wedged it in there. The new one is going in with a good smear of grease.
Copper grease or any waterproof grease is a good idea to use
