First of all Merry Christmas and Happy New Year to all.
Decided to give the fork a bit of an overhaul as it was the only job I didn't do when I got the bike. One of the forks had obviously been worked at before as the fluid was fairly clean. The other one I have seen better stool samples, including a rusted seal.
My question is. Is it worth flushing out the legs before rebuilding. If so what would I use. Something like brake and clutch cleaner perhaps?
Marty
Fork service
- Has liked: 14 times
- Been liked: 46 times
Re: Fork service
I'd drain the fork with the dirty oil then empty the clean oil from the other leg into the one that had the dirty fluid. Pump it through a bit then drain before filling both legs with fresh oil.
- Has liked: 4 times
Re: Fork service
Pleased to report the wee job is going well. One last question. Do you wait until you have the wheel back on and her sitting on own weight, then release the air screw then tighten it, or does it make much difference
- Stu
- Administrator
- Has liked: 619 times
- Been liked: 598 times
Re: Fork service
Missed this but for future reference in the past I have cleaned forks out with petrol
Pour some in give it a slosh about without pumping the forks as the petrol will wash all oil away
Then pour it out and leave the forks upside down to drain all the petrol out
Stick a match to it to make it quicker
(PS I am joking! don't do this!)
I have always planned it to leave the forks to drain overnight and the petrol will be all evaporated by then
As for the air screw! not sure on the BMW's but on other bikes you assemble everything off the bike with it all set then just fit them to the bike I can't see it been any different
Re: Fork service
Thanks Sakm. Had them built before noticing your reply, but set the air screw as you suggested.
- Has liked: 1428 times
- Been liked: 406 times
Re: Fork service
Assemble the forks then release the air
Re: Fork service
