Red battery warning light
W8NONU
Bike Model and Year: R1200RT 2016
Has liked: 6 times
Post by W8NONU »
Very confused. I checked battery voltage at rest, under load and charging system output. All check out ok. Bike starts and runs fine, but I noticed no headlight coming on and low fuel light is on although tank is full. The two fuses under the seat are good.
jesim1
Has liked: 142 times
Been liked: 83 times
Re: Red battery warning light
Post by jesim1 »
Has anything been fitted that may be annoying the CANBUS? :shock:
W8NONU
Has liked: 6 times
Post by W8NONU »
No, everything is stock.
W8NONU
Has liked: 6 times
Post by W8NONU »
I replaced the two fuses and the 50 amp fuse has continuity but no power shows going through it when bike is running.
W8NONU
Has liked: 6 times
Post by W8NONU »
Took the bike to the dealer and problem ended up being a bad ground module (the end of the Canbus system). $1,000 later and I’m riding again.
