Zumo XT
Zumo XT
I know that the wonder wheel does not work with the XT.
But what i would like to know is, does the bike info you get on the Nav 5 & 6. does the XT give this info to ?
Edit...
Also is there a charging problem when the XT is fitted to the Nav mount on the RT with a 3D adaptor.
Re: Zumo XT
No you get no information on the zumo from the bike
There was a charging issue which I discovered a fix for and reported it to the developer.
The chip he used for the adapter was dropping the voltage below 5v once the bike started thus stopping it charging after a while
I replaced the chip with one that could adjust the voltage and I set it to about 5.2 volts and it's worked perfect since.
I let the developer know and I believe he fixed the issue
See here https://www.zumouserforums.co.uk/viewtopic.php?t=1318
Re: Zumo XT
Thank you for the Stu :thumb:
Also will the XT fit using its own mounting in the same place as the bmw unit, if the bmw navigator mount is removed.
Re: Zumo XT
It will but it's a massive pain to get it out as the release is on the top of the mount and you need a tool to get in to release it
More hassle than it's worth in my opinion
Fourbears
Been liked: 6 times
Re: Zumo XT
Post by Fourbears »
I have the 3D adapter and if I’m removing the XT I just press the button on top of the dash and remove the whole thing. Easy. The actual XT release is hidden by the upper dash panel so if you can get to it and take the XT off the mount is left.
Re: Zumo XT
Stu wrote: Sun Aug 25, 2024 8:10 pm It will but it's a massive pain to get it out as the release is on the top of the mount and you need a tool to get in to release it
I noticed that you are admin for that site as well
Re: Zumo XT
Doctor T wrote: Mon Aug 26, 2024 1:31 pm I noticed that you are admin for that site as well
did you not know, Stu owns the internet :-D
Re: Zumo XT
Yes that's right :lol:
It was another forum that was going to be lost
Re: Zumo XT
Stu wrote: Mon Aug 26, 2024 1:49 pm Yes that's right :lol:
Anymore?
Re: Zumo XT
Doctor T wrote: Mon Aug 26, 2024 2:50 pmAnymore?
Just the 3!
Www.themotorbikeforum.co.uk
Www.1200rt.com
Www.zumouserforums.co.uk
For now 😂
Re: Zumo XT
Amazing you get any work done running 3
7vwh
Has liked: 18 times
Been liked: 40 times
Re: Zumo XT
Post by 7vwh »
Stu wrote: Mon Aug 26, 2024 3:27 pm Www.themotorbikeforum.co.uk
Holy sh1t! Forgot I was a member of this one, last post in 2012😳
beemerboy9
Been liked: 25 times
Re: Zumo XT
Post by beemerboy9 »
EasyRider wrote: Sun Aug 25, 2024 8:05 pm Thank you for the Stu :thumb:
I would NOT remove the BMW mount.
I have fitted the Wunderlich/Oldtimers Satnav electric locking device to my non-TFT bike. This locks the BMW release button and the AD3P adapter fit is so precise that the XT release button cannot be accessed.
I leave the XT locked onto the bike for rest stops, but don't chance it overnight.
