Hi All, just a quick one.
I've seen loads and loads of threads about sound bombs, but can't find the answer so I'll ask the question:
2015 1200RT with 1x standard horn mounted in the fairing. Looking to upgrade with EZCan system including horn. Just need to know if I need to get the SPLIT sound bomb and do some magic fitting it, or if the solid unit will fit in place.
Also - Mounting bracket. There seems to be a few options available. Is a bracket necessary or will it bolt on to where the original is?
Anyone know the answer?
Cheers.
Sound bomb or SPLIT sound bomb.
- Has liked: 1428 times
- Been liked: 406 times
Re: Sound bomb or SPLIT sound bomb.
Standard sound bomb can go in the same space as the OE horn. You can buy a bracket or make one yourself. On my bike I have a standard hon and a sound bomb Both fit where the OE horn sits. Both use about 7w. Anything above will trip the cambus.
- EasyRider
- Has liked: 151 times
- Been liked: 364 times
I have the sound bomb one piece and it is great and fits under the headlight still.
- Bike Model and Year: 2015 RT 1200
- Has liked: 9 times
Brilliant, that'll make life easier. Cheers for the replies.
Remember, ride to arrive alive!
James.
James.
- Been liked: 25 times
I have the low tone horn from a BMW 5-series car. Naturally it is compatible with the existing bike plug.
