stuck windscreen
GravenorTG
Bike Model and Year: R1200RT LC 2016
stuck windscreen
Post by GravenorTG »
New Forum Member,
R1200RT LC 2016 plate.
Please can anyone help/advise?
Screen stuck in up position. Attempted to recalibrate the controller using my GS-911 and the calibration process starts and abruptly stops showing an error. I have tried a multitude of time going through the clearing faults and repeating the calibration to no avail.
I have accessed the real time screen section of the GS-911and saw that the switch is operating. (it should because I just spent a small mortgage on purchasing it from MPS in the Netherlands!
I am about to go through the task of stripping down the front end of the m/c in order to examine the operating linkage in case of a mechanical failure.
I have never calibrated any process before so I may be barking up the wrong tree, but after owning/riding since 1972 I normally scratch about and find some form of solution to the joys of owning a motorcycle and mechanical bits and bobs are up my street so to speak.
If anyone can just point me in the right direction I will be ecstatically grateful to end the misery I am going through with a shitty screen to contend with during our "summer" in the UK.
Thank you for reading my plea :blah:
I will await some kind directives from the vast amount of knowledge that must exist on such a popular marque as BMW.
beemerboy9
Been liked: 25 times
Re: stuck windscreen
Post by beemerboy9 »
GravenorTG
Thank you for pointing this issue out to me. :?
I can see how a dislodged pivot could prevent the screen from operating but until i take the front off I won't be able to fully understand what the issue may be, mechanical or electrical as I am not too clever with electrical circuitry and I am hoping that the stuck screen doesn't mean that the motor is gerfunkt!
beemerboy9
Pivot Pins for Windscreen 2019 RT
The part number for the PIN is 4663 7693 990
The part number for the Circlip is 0712 9909 733
May suit other years and models e.g. 2014--> R1200RT and 2019--> R1250RT with TFT.
GravenorTG
Thanks John. I’ll keep you posted
Michael.Larsson
Bike Model and Year: R 1200RT 2010
Sweden
Post by Michael.Larsson »
Hi, i have the same problem? did you solved yours?
