Connected app and paired helmets
MacFazer
Bike Model and Year: R1250rt 2024
Has liked: 3 times
Post by MacFazer »
Hi guys,
I have a 2024rt. Everything works well with the connected app until I pair my helmet intercom with my pillion. That action disconnects the helmets from the bike.
Helmets are both Schuberth SC10 (Sena).
Does anyone know where the problem lies.
Many thanks,
Mac.
LochiesDad
Has liked: 6 times
Been liked: 56 times
Re: Connected app and paired helmets
Post by LochiesDad »
Hi Mac
I had that similar problem on my 2023 1250GSA paired with a Schuberth C5. It ended up being the sequence of connecting the bike & iPhone which took 4 or 5 attempts to correct despite following BMW & Schuberth instructions. After around 4 attempts and much blue air I discovered my Schuberth comms software needed to be updated. Back to the laptop, update downloaded, re-pairing helmet then iPhone and it worked. Next problem was the darn wheel on the handlebar wouldn't control the volume so the software update fixed one problem but created another.
Not sure is any of that will help.
Good luck with your challenge.
Thankfully I saw sense and got rid of the GSA and now have a much calmer life with the RT
Loopers
Bike Model and Year: R1250RTLe 2023
Has liked: 3 times
Been liked: 12 times
Post by Loopers »
Have you tried pairing both helmets to the bike? You can pair the second helmet as pillion and I believe you can select what they hear but I could be wrong on that.
jesim1
Has liked: 142 times
Been liked: 83 times
Post by jesim1 »
I don't pair my helmet to the bike :roll:
I suppose it depends what functionality you want, but as you have already experienced, sometimes the grief is just too much for the odd time it will be a benefit to you.
As above though, make sure everything is up to date before you start, and then try different ways to connect it, it should not matter, but it does, and some apps or units need to be the lead one, lets just hope you don't have two conflicting :cheers:
MacFazer
Has liked: 3 times
Post by MacFazer »
LochiesDad wrote: Sun Nov 24, 2024 9:43 am Hi Mac
Thanks for the advice. I've tried every combination of connecting the phone and helmets to the bike, I can get satnav instructions to both helmets, but as soon as I pair the helmets together both disconnect from the bike. I'm fairly sure there's an issue with the Schuberth/Sena as I have lost a number of the configuration menu options.....and Schuberth either can't or won't offer a solution.
How's the weather in Turra ?
MacFazer
Has liked: 3 times
Post by MacFazer »
Loopers wrote: Sun Nov 24, 2024 10:50 pm Have you tried pairing both helmets to the bike? You can pair the second helmet as pillion and I believe you can select what they hear but I could be wrong on that.
Aye, that works fine, I even get satnav instructions to the wife's helmet so she can tell me everything I'm doing wrong. It's pairing the helmets to each other to get intercom that disconnects the helmets from the bike. Ach well, having to forgoe speaking to the wife in favour of the Satnav isn't so bad :-D
MacFazer
Has liked: 3 times
Post by MacFazer »
jesim1 wrote: Mon Nov 25, 2024 12:30 am I don't pair my helmet to the bike :roll:
I've run out of swears and blood pressure to high, so resigning myself to the fact that it'll never work ! Neither Schuberth nor BMW offering any constructive advice......they've already got my money :mad:
How many bluetooth channels do the headsets have?
If you only have one channel then you can only have one bluetooth device connected
If you have two then you need to figure out how to connect to the second channel as it sounds to like you're connecting everything to the same channel hence why it kicks the bike out
Sherseni
Post by Sherseni »
Hey Mac, I had a similar issue with my intercoms once. It might be a Bluetooth conflict between the bike and the intercoms. What worked for me was unpairing the helmets from the bike's app first, then pairing them with the intercoms. Also, double-check if there's a firmware update for either the bike or the helmets—sometimes that helps smooth things out.
