Help plz, yellow triangle explanation point
JasonFl
Bike Model and Year: R1200RT 2005
Has liked: 3 times
Post by JasonFl »
2006 RT
-changed out battery for a new one
-everything seemed to go just fine
—but yellow caution triangle stays on dash and will not turn
—also, the fuel and temperature gauges are frozen at the point when I changed to new battery they don’t adjust??
-I unhooked new battery twice waited 15mins and reconnected in effort to reset the dash/ECM but that did not fix anything
-all lights are working fine
-oil is new and not low at all
-everything seems to work just fine except frozen yellow triangle and fuel / temp gauges
Ideas on how I can unfreeze these ?
Thank you in advance-
Jason
MarkW
Bike Model and Year: R1200RT 2012
Been liked: 6 times
Re: Help plz, yellow triangle explanation point
Post by MarkW »
I fear you will need to read the fault codes to figure this one out. Do you know anyone local wiith a GS-911 or equivalent?
I'm assuming the light stays on after riding the bike, because it won't go off until the abs check has completed at about 5mph.
JasonFl wrote: Sun Jan 19, 2025 8:36 pmYellow caution triangle stays on dash and will not turn.
Does this mean the engine won't crank or start.
JasonFl
Has liked: 3 times
Post by JasonFl »
No starts and runs just fine- yellow triangle simply stays on and fuel gauge frozen at point where battery was changed out- all else runs perfect
Thanks for support
Yellow Light.jpg (6.94 KiB) Viewed 1214 times
Just a thought, if the yellow light is on the fuel gauge is frozen, I wonder if it's the dreaded fuel strip (level gauge) at fault.
JasonFl
Has liked: 3 times
Post by JasonFl »
Interesting thought, didn’t cross my mind, I’ll try and assess that- it’s also the Temp gauge that froze (those two gauges have stayed right where they were during time of battery swap out) bizarre x
Thx for idea-
AFAIK, I don't think that the engine temperature gauge would trigger the yellow triangle warning light, could be wrong.
