iPhone BMW Connected Ride automation instructions
RaP
Bike Model and Year: R1250RT MY2023
Germany
Post by RaP »
With inspirational input from some Users on other platforms I created an iPhone "Shortcut App" instruction sheet for two automations.
1rst a "WiFi plus App open" shortcut-procedure and for those who still have Problems with the connection 2nd a "Bluetooth-Wifi workaround" which switches a probably still connected home WiWi shortly off and on again to force a new connection with the Bike.
After programming that throwing your unlocked iPhone in the cubby is the last you have to do with that device. No WiFi acceptance needed and Maps start and -more important- restarts on its own. In case you need to start a planned route it's obvious that you need to choose and start it manually.
Screenshots are now bilingual so you should be able to find the right buttons. If not, hand the phone over to your grandkids.:-) Have fun! It works!
Rudolf
New version:
BMW Connected App automation V1.4.pdf
(750.64 KiB) Downloaded 103 times
jesim1
Has liked: 142 times
Been liked: 83 times
Re: iPhone BMW Connected Ride automation instructions
Post by jesim1 »
I'll give this a go next week with a bit of luck :cheers:
Efonsec
Bike Model and Year: RT 1250/2023
Brazil
Post by Efonsec »
HI, there
Nice job.
Finally got it to work, but still ask me to join BMW WiFi every time I stop for gas or something else.
Am I missing something?
RaP
Germany
Post by RaP »
If you follow exactly the instructions it ahouldn‘t. Probably you missed the sub step „run immediately“ which is way down on the screen. The default setting is „Run after confirmation“ which leads to your result.
