No Power
Crash 9411
Bike Model and Year: 2015 R1200Rt
No Power
Post by Crash 9411 »
I took all of the plastic off my bike to check the air filter, and give it a good cleaning, and when I buttoned it back up and het the power up button I got no response whatsoever ever, everything is black and the bike now has no power to anything. Any ideas? I can’t connect my OBD LINK because of the power issue, and I did check the battery and it is fully charged.
Has liked: 79 times
Been liked: 65 times
Re: No Power
You must have disconnected something. I have removed that plastic numerous time with no issues.
Could be a fuse.
Battery got juice?
Re: No Power
Have you had the battery off?
Crash 9411
Re: No Power
Well I figured out the problem, I was under the impression that there were no fuses because of the canbus system, I was wrong, I found 2 mini fuses under the riders seat inside a connector. There was a 7.5 that was intact and a 15 that was blown. Replaced the fuse and now I am back up and running. It is interesting that every thing I read said there were no fuses, evidently not the case.
Thanks Crash
