high beams
turdboman
high beams
Post by turdboman »
any thoughts on using high beams in the day time ?
Gman1969
Re: high beams
Post by Gman1969 »
Personally I find it irritating and unnecessary speaking from a car driver and a biker
guest3074
Re: high beams
Post by guest3074 »
Gman1969 wrote: Personally I find it irritating and unnecessary speaking from a car driver and a biker
+1
And here in the UK although not specifically illegal, you could get points for driving without due care and consideration,
T6pilot
Re: high beams
Post by T6pilot »
On this side of the pond, most ride with their brights on in daylight has we have so many distracted drivers, their is a term triangle of visibility, brights and Photon Blasters create this. At night low beams
I've often thought if a locomotive headlamp could be installed I would be the first
7vwh
Has liked: 18 times
Been liked: 40 times
Re: high beams
Post by 7vwh »
Benchmark wrote: +1
There is a specific offence of causing unnecessary dazzle, £50, no points!
Peter Baker
Has liked: 14 times
Been liked: 7 times
Re: high beams
Post by Peter Baker »
+1 its just unnecessary in my view, Peter
Little-Brit
Re: high beams
Post by Little-Brit »
It's just inconsiderate, bordering on rude.  No need to do it especially with the very effective LED running lights.
Re: high beams
7vwh wrote:There is a specific offence of causing unnecessary dazzle, £50, no points!
Does the same apply to using front or rear fog lights in normal visibility (day or night) conditions.
step2534
Re: high beams
Post by step2534 »
  Yes specific offences for both front and rear foglights, only to be used in reduced visibility day or night.
guest3074
Re: high beams
Post by guest3074 »
step2534 wrote:   Yes specific offences for both front and rear foglights, only to be used in reduced visibility day or night.
Just a shame due to cut backs that traffic dept's have shrunk over the years  :(
7vwh
Has liked: 18 times
Re: high beams
Post by 7vwh »
DaygloDavid wrote: Does the same apply to using front or rear fog lights in normal visibility (day or night) conditions.
It's harder to prove the dazzle element during daylight, especially on a sunny day, night time is a different matter, especially in the wet!
futterweasel
Re: high beams
Post by futterweasel »
I think it is very inconsiderate to use high beams in the daytime and dazzle oncoming drivers/riders, I flash my lights several times and then leave them on full beam if oncoming vehicles do it to me. It's a shame the police don't enforce the rules of the road a bit more.
futterweasel
Re: high beams
the cars are now equipped with auto dip headlights hopefully the bikes will be the same soon that should stop the tossers from dazzling you when they are coming towards you :wonder:
Maz12
Re: high beams
Post by Maz12 »
futterweasel wrote: the cars are now equipped with auto dip headlights hopefully the bikes will be the same soon that should stop the tossers from dazzling you when they are coming towards you :wonder:
Hope they can come up with a auto-switch off for front and rear fog lights when the visability is over 100m
People seem to use their front fogs all the time, regardless of weather conditions
iride4u
Re: high beams
Post by iride4u »
I ride with the low beams and the LED fog lamps on at all times. This gives a good triangle. The K1600 has Clearwaters set at 50% as not to blind someone the RTP has BMW LEDs.
