Factory LED lights added - don’t work
zxbob
Post by zxbob »
i have a 2108 R1200RT and I added the factory LEDs and they don’t turn on. I bought the lights, wiring harness and handlebar switch from BMW thinking it’s plug and play ..... guess not. Any suggestions would be appreciated.
Bob
Good parts ain’t cheap and cheap parts ain’t good !
bighopper
Re: Factory LED lights added - don’t work
Post by bighopper »
I believe that you have to have them 'Turned On' by your local BMW stealer. Control by ECU I think.
exportman
Has liked: 6 times
Been liked: 41 times
Post by exportman »
bighopper wrote: I believe that you have to have them 'Turned On' by your local BMW stealer. Control by ECU I think.
Yup  thats the solution
gogs01
Post by gogs01 »
Are they supposed to come on at "ignition on" or only with the headlight ?  Once the dealer has activated them that is ?
zxbob
Post by zxbob »
Thank you guys
zxbob
Post by zxbob »
$ 105.00 at the stealership and they work !
Bikerman1042
Post by Bikerman1042 »
zxbob wrote: i have a 2108 R1200RT and I added the factory LEDs and they don’t turn on. I bought the lights, wiring harness and handlebar switch from BMW thinking it’s plug and play ..... guess not. Any suggestions would be appreciated.
Bob
I think you will need what is referred to as a can ioener, ie a canbus connector box to enable these and other accessories to work on a CANBUS wired bike.  Try Ebay
Good Luck
LC cool
Post by LC cool »
If its BMW genuine parts go back to your dealer they have to activate them.
If they are BMW aux lights, you need the dealer to switch them on. When you switch on the ignition, they come on initially, then you have to use the switch to switch them on. You only need a Cansmart, or Hex Ezcan if you are running aftermarket lights, such as Denali or Clearwater
