Damn headlight bulb replacement!
jackronner
Bike Model and Year: 2007 RT
Been liked: 12 times
Post by jackronner »
Never seems to get easier, nor do my hands get any smaller.  Do you think it was designed to get us to use BMW dealers service?
I've tried various techniques (and am willing, please, to hear more), but it seems best to me to first affix the new bulb with the clamps.  Have tried attaching the wires before inserting the bulb, but the wires keep getting in the way of the snap-down clamps.  Frustratingly, you get a better view of the right lamp assembly by turning the bars all the way right, but more hand space by turning it left.
The one thing I do recommend highly is using an approximately 8" locking surgical hemostat.  Helps in removing the wires and replacing them, as well as positioning and holding the bulb in place as you engage the wire clamps.
Have they improved this design in post-hex head models?
Dartman340ta
Re: Damn headlight bulb replacement!
Post by Dartman340ta »
Xxx hands I took the left side covers off moved the horn  2 hours cuzzing I got it in there.  If they would have the wire lock hang to fall down it would have been much easier. I think.
jackronner wrote:Have they improved this design in post-hexhead models?
No, it's the same for a Camhead. Removing the upper fairing panel (4 screws) improves access especially on the RHS where the cruise control unit is.
Nick Evans
Been liked: 6 times
Post by Nick Evans »
I remove the side panels, mirrors and dash surround, this makes access way easier. I takes me about 10 minutes to remove all the plastic (16 screws total), and about 10 minutes to change all 3 bulbs, with another 10 minutes to get all the plastic back on. I have a 2009 machine and XL hands. Removing the screen makes getting to the 2 screws in the top of the dash easier, which is an extra 6 screws and 2 minutes to remove or replace.
rangemaster728
Post by rangemaster728 »
I have 2 Hexheads...I use a short chunk of cut garden hose stuck onto the back of the lamp and sit in the front of the bike and reach around underneath while I’m looking through the headlight assembly. I replaced enough of these that I’ve gotten manageable at it without tearing up my hands LOL.
jackronner
Rangemaster,  I had the same idea about the hose but couldn't find the right size, so used the hemostat while looking from the front as you did.  I take it you put the bulb in before attaching the wires (the hemostat's particularly helpful with that since your hand doesn't block your view).  It's been suggested that removing the upper fairing (four screws) helps.  O for the days of just one headlight!
H7 LED
What a great idea, just tried some 1/2" ID garden hose over the two spade connectors on a H7 bulb, works a treat.
Recently had to replace two headlight bulbs, used the garden hose trick.
Has liked: 773 times
Been liked: 143 times
I think I’ll have a practice at changing the bulbs one day … perhaps fit Phillips ED ( extended driving long life bulbs. I can’t be bothered with the cyclops kit and I hear it’s not recommended to fit cheaper led bulbs on their own ?.
David. wrote: Sat May 11, 2024 4:17 amRecently had to replace two headlight bulbs, used the garden hose trick.
David. wrote: Fri Jun 07, 2024 6:05 pmHose.jpeg
How did it go 🤔, when I change mine I’ll go for the Phillips extended driving/ long life bulbs.
jackronner
Hahahaha !! There I was patting myself on the back for having thought of this trick myself, and then I see 10 people who thought of it years ago!
