Thought on using the ZumoXT on a 2021RT
wethead
Post by wethead »
...any thoughts on this
Hors Piste
Re: Thought on using the ZumoXT on a 2021RT
Post by Hors Piste »
Going by my experience with the BMW system it sounds like a good idea...
DavidMcK
Post by DavidMcK »
Its hard to give a definite yes or no.  It would seem iPhones are problematic and if you are an Apple person then its probably going to save some heartache.
If you are an Android person then you can think of a second phone as your old GPS/ZumoXT and donate it to the bike.  If you go that way the TFT works well (once you have a simple way of importing routes, I use MyRouteApp and its simple)  With the TFT you can zoom in/out on maps, repeat instructions, search for POI's, skip waypoints etc. with the wonderwheel.
Time will tell if mobile phones are robust enough to live in pockets without vibration damping.
PeteM
Post by PeteM »
DavidMcK wrote: Time will tell if mobile phones are robust enough to live in pockets without vibration damping.
Bubble Wrap
Been liked: 25 times
Post by beemerboy9 »
PeteM wrote:
Bubble Wrap
Possible overheating in high ambient temperatures.
wethead
Post by wethead »
I need an aftermarket bracket/rack to mount a ZumoXT on a 2021RT
Normski brake reservoir or clutch lever RAM bolt, https://www.normski-bmw.co.uk/
60Aviator
Bike Model and Year: 2017 GSA & 2021 R1250RT
Has liked: 8 times
Been liked: 14 times
Post by 60Aviator »
You mean like this? App works but has limited search options and not easy/fast to work while riding. Just to zoom in or out requires too much menu options to go through. Plan route and load into GPS, doesn't get easier than that too.
[size=5px]https://www.wunderlichamerica.com/BMW_M ... Adapter_LC[/size]
Ram ball threaded for that adapter
paynes1
Post by paynes1 »
I don't have an XT but I still use my Zumo 660. I will continue to use it untill/if I get the connectivity/voice issues resolved with the TFT and App on the new bike.
I suspect that I will probably use it after that when leading tours etc as they can be quite long and complicated when planned on BaseCamp. I've included some pictures if they are of any use.
Steve P
wethead
Post by wethead »
[size=15px]How do you guys connect an external GPS to a 2021RT?[/size]
