Thought on using the ZumoXT on a 2021RT
...any thoughts on this
Re: Thought on using the ZumoXT on a 2021RT
Going by my experience with the BMW system it sounds like a good idea...
Its hard to give a definite yes or no. It would seem iPhones are problematic and if you are an Apple person then its probably going to save some heartache.
If you are an Android person then you can think of a second phone as your old GPS/ZumoXT and donate it to the bike. If you go that way the TFT works well (once you have a simple way of importing routes, I use MyRouteApp and its simple) With the TFT you can zoom in/out on maps, repeat instructions, search for POI's, skip waypoints etc. with the wonderwheel.
Time will tell if mobile phones are robust enough to live in pockets without vibration damping.
DavidMcK wrote: Time will tell if mobile phones are robust enough to live in pockets without vibration damping.
Bubble Wrap
- Been liked: 14 times
PeteM wrote:
Bubble Wrap
Possible overheating in high ambient temperatures.
I need an aftermarket bracket/rack to mount a ZumoXT on a 2021RT
- Been liked: 251 times
Normski brake reservoir or clutch lever RAM bolt, https://www.normski-bmw.co.uk/
- 60Aviator
- Bike Model and Year: 2017 GSA & 2021 R1250RT
- Has liked: 3 times
- Been liked: 6 times
You mean like this? App works but has limited search options and not easy/fast to work while riding. Just to zoom in or out requires too much menu options to go through. Plan route and load into GPS, doesn't get easier than that too.
[size=5px]https://www.wunderlichamerica.com/BMW_M ... Adapter_LC[/size]
Ram ball threaded for that adapter
- Bike Model and Year: 2022 R1250RT
I don't have an XT but I still use my Zumo 660. I will continue to use it untill/if I get the connectivity/voice issues resolved with the TFT and App on the new bike.
I suspect that I will probably use it after that when leading tours etc as they can be quite long and complicated when planned on BaseCamp. I've included some pictures if they are of any use.
Steve P
Steve P
[size=15px]How do you guys connect an external GPS to a 2021RT?[/size]
