full beam. Why?
full beam. Why?
Sitting here watching video's on YT. One thing ive noticed is that most riders drive with full beam on all the time. OK may help in cities but these riders are in the open countryside.
Do you ride about with full beam on all the time?
Re: full beam. Why?
Haloes and yellow Clearwater Darla lights. Surely main beam’s likely to drown your indicators…
Re: full beam. Why?
Doctor T wrote: Thu Oct 06, 2022 5:06 pm Do you ride about with full beam on all the time?
No, I find 2 x dipped beam perfectly adequate.
Re: full beam. Why?
Steve398 wrote: Thu Oct 06, 2022 6:08 pm Haloes and yellow Clearwater Darla lights.
Could yellow lights be confused with indicators.
Re: full beam. Why?
Normal day to day riding I just have my normal beam on.When I'm commuting the bike(GSX1250)has the high beam on.Anything for the scroats to see me,and even then it doesn't work :evil:
Ed Harley
Has liked: 16 times
Finland
Re: full beam. Why?
Post by Ed Harley »
Doctor T wrote: Thu Oct 06, 2022 5:06 pmDo you ride about with full beam on all the time?
Used to back in the day but not anymore.
Bono estente!
Re: full beam. Why?
I've never used full beams in the daylight. I have my dips on and a pair of yellow lens 10w spots mounted on my fork legs.
Re: full beam. Why?
Doctor T wrote: Thu Oct 06, 2022 7:44 pmI have a pair of yellow lens 10w spots mounted on my fork legs.
Re: full beam. Why?
Depending on what its like outside depends on the lights I use
No sun then daytime haloes is fine
Bright sunshine especially a low blinding sun then its headlights on and fogs on as if its a blinding light I want to be seen
Dark just headlights on fogs off as people flash at me as they are too bright
High beam is only every used when required and when there is no other vehicles in front or oncoming
We are trying to be seen here not blind everyone so they can't see as that just defeats the object
Re: full beam. Why?
I don’t think so…
Re: full beam. Why?
sakm wrote: Thu Oct 06, 2022 8:03 pm
This^^^
Sharkfighter
Been liked: 26 times
Re: full beam. Why?
Post by Sharkfighter »
I’ll play devils advocate here and have you considered what the law says about it?
Rule 114
You MUST NOT
use any lights in a way which would dazzle or cause discomfort to other road users, including pedestrians, cyclists and horse riders
use front or rear fog lights unless visibility is seriously reduced. You MUST switch them off when visibility improves to avoid dazzling other road users (see Rule 226).
In stationary queues of traffic, drivers should apply the parking brake and, once the following traffic has stopped, take their foot off the footbrake to deactivate the vehicle brake lights. This will minimise glare to road users behind until the traffic moves again.
Law RVLR reg 27
Most people think it only applies to hours of darkness, but the law above does not mention that. Therefore it applies at all times. Just a thought.
Re: full beam. Why?
Are front yellow lights considered as fog lights.
More discussion on the matter here, viewtopic.php?p=49694&hilit=fog+lights#p49694
Marvin2Shoes
Has liked: 76 times
Been liked: 17 times
Australia
Re: full beam. Why?
Post by Marvin2Shoes »
If you are ever riding in Australia make sure you use low beam during the day or, as my wife discovered, you'll find a policeman writing you an infringement notice and it will cost. It doesn't matter if you mention that you didn't realise you had your high beams on as ignorance is never a defence under law. I did, however, feel a little better after muttering about 'revenue raising' from the relative safety of the passenger seat ;)
2011 R1200RT Highly Modified
Re: full beam. Why?
Steve398 wrote: Thu Oct 06, 2022 8:04 pm I don’t think so…
Mine are mounted just about the calipers. Can't see how these can be confused with indicators. Also, they are yellow and not orange.
With my spots/daylights mounted as they are they give a triangle effect. I think lambs mount under the mirrors can cause more confusion in the day light
