full beam. Why?
- Has liked: 1434 times
- Been liked: 406 times
full beam. Why?
Sitting here watching video's on YT. One thing ive noticed is that most riders drive with full beam on all the time. OK may help in cities but these riders are in the open countryside.
Do you ride about with full beam on all the time?
- Steve398
- Has liked: 474 times
- Been liked: 404 times
Re: full beam. Why?
Haloes and yellow Clearwater Darla lights. Surely main beam’s likely to drown your indicators…
- Been liked: 477 times
- Been liked: 395 times
Re: full beam. Why?
Normal day to day riding I just have my normal beam on.When I'm commuting the bike(GSX1250)has the high beam on.Anything for the scroats to see me,and even then it doesn't work
- Ed Harley
- Has liked: 11 times
- Been liked: 75 times
Re: full beam. Why?
Used to back in the day but not anymore.
Re: full beam. Why?
I've never used full beams in the daylight. I have my dips on and a pair of yellow lens 10w spots mounted on my fork legs.
- Stu
- Has liked: 620 times
- Been liked: 598 times
Re: full beam. Why?
Depending on what its like outside depends on the lights I use
No sun then daytime haloes is fine
Bright sunshine especially a low blinding sun then its headlights on and fogs on as if its a blinding light I want to be seen
Dark just headlights on fogs off as people flash at me as they are too bright
High beam is only every used when required and when there is no other vehicles in front or oncoming
We are trying to be seen here not blind everyone so they can't see as that just defeats the object
- Steve398
Re: full beam. Why?
I don’t think so…
- C93CF8F8-ED42-4274-B463-0D59E5F84F4E.jpeg (853.54 KiB) Viewed 4416 times
- Has liked: 99 times
- Been liked: 227 times
- Sharkfighter
- Been liked: 23 times
Re: full beam. Why?
I’ll play devils advocate here and have you considered what the law says about it?
Rule 114
You MUST NOT
use any lights in a way which would dazzle or cause discomfort to other road users, including pedestrians, cyclists and horse riders
use front or rear fog lights unless visibility is seriously reduced. You MUST switch them off when visibility improves to avoid dazzling other road users (see Rule 226).
In stationary queues of traffic, drivers should apply the parking brake and, once the following traffic has stopped, take their foot off the footbrake to deactivate the vehicle brake lights. This will minimise glare to road users behind until the traffic moves again.
Law RVLR reg 27
Most people think it only applies to hours of darkness, but the law above does not mention that. Therefore it applies at all times. Just a thought.
Rule 114
You MUST NOT
Law RVLR reg 27
Re: full beam. Why?
Are front yellow lights considered as fog lights.
More discussion on the matter here, viewtopic.php?p=49694&hilit=fog+lights#p49694
- Has liked: 76 times
- Been liked: 17 times
Re: full beam. Why?
If you are ever riding in Australia make sure you use low beam during the day or, as my wife discovered, you'll find a policeman writing you an infringement notice and it will cost. It doesn't matter if you mention that you didn't realise you had your high beams on as ignorance is never a defence under law. I did, however, feel a little better after muttering about 'revenue raising' from the relative safety of the passenger seat
2011 R1200RT Highly Modified
Re: full beam. Why?
Mine are mounted just about the calipers. Can't see how these can be confused with indicators. Also, they are yellow and not orange.
With my spots/daylights mounted as they are they give a triangle effect. I think lambs mount under the mirrors can cause more confusion in the day light
