Hi All, Got a warning light on my (2019) RT1250 dash panel yesterday, which turned out to be the front headlight bulb that had gone to heaven. Is it just me or do I have to get in touch with a midget in order to change the bulb. I have had a look at the access to the bulb cover and OMG there is no room to work.
Has anyone done the job b4 and can I have some tips ??
Front Headlight Bulb Removal
- Sharkfighter
- Been liked: 23 times
Re: Front Headlight Bulb Removal
I’ve got a 2013 RT and I’ve had to change two bulbs. My hands aren’t small either, size 10 or extra large gloves. All I did was take the plastic off on the side affected, this gave some more room. I found it straight forward enough and didn’t take any skin off my hands either. I’ve even done it in the car park at the hotel I stayed in in Belgium last year, took around 10 minutes from start to finish.
- Bike Model and Year: R1250RT 2019
- Has liked: 2 times
I think the 2013RT is different to the 2019 model. If my blown headlight bulb would have been one of the two side one's it would have been easier to change as all I need to do is remove the speaker and they are right behind it. The problem is that the blown bulb is the centre one and there is nothing, I think, I can remove to access it.
Managed to change the bulb. It's a B***H of a job and it took 1hr 20min to complete. Lets hope the new bulb lasts a few years.
- Steve398
- Has liked: 473 times
- Been liked: 404 times
Having read lots of the horror stories on changing the headlight bulbs I bit the bullet and had Cyclops LED’s installed on my 2018 RT. It just seemed easier in the long run, pricey now less pain later… literally!
- jclaudej
- Bike Model and Year: 1250 RT 2019
- Has liked: 11 times
- Been liked: 16 times
- Contact:
Hello,
I also have a RT 1250 from 2019 and concerning the low beam it is possible to change the bulb without dismantling the fairings.
I specify that I have big hands XL see XXL;)
To do this, position yourself in front of the motorcycle and pass your hand under the fairing.
Then unscrew the cover and the most difficult remove the clips which for me is very hard.
Then with cotton gloves (to protect the bulb) change it.
Then proceed in reverse order.
My eve would be to find an LED bulb that fits in this clutter and that would illuminate better.
Good luck
Good luck
- Randyjaco
- Has liked: 80 times
- Been liked: 65 times
This is how far I got without removing Tupperware. After I got everything disassembled, it took a pair of pliers to get the left clip off. It was not a fun experience.
Maybe this photo will help others that are feeling around in the dark in a parking lot.
Hopefully you will have better luck
- PXL_20221003_163913509.jpg (512.72 KiB) Viewed 4555 times
- Been liked: 476 times
A tip from this thread is to use a short length of garden hose to hold the bulb, viewtopic.php?p=56466&hilit=garden#p56466
- jclaudej
- Contact:
Hello,
I just installed the H7 LED bulb below (low beam)
https://fr.aliexpress.com/item/10050049 ... pt=glo2eng
If the operation was as tedious as with a standard bulb, I did not encounter any particular problem.
My first impressions are quite positive.
1 - Test over 50 meters (it is currently raining a lot at my place and the roads are slippery) but no fault on the dashboard
2 - The beams seem similar (shape) to that of the halogen bulb but on the other hand it is much more powerful.
3 - The size of the bulb is identical to a classic H7 lamp, the fan is in the body of the LED bulb.
4 - A small noise (fan) is slightly audible only with the engine off.
Still to try, when the weather will be kinder
Link to H1 => https://fr.aliexpress.com/item/10050050 ... pt=glo2fra
Always without CanBus mistake
Small video of the result
