Foot peg lowering kit for RT
Has liked: 490 times
Been liked: 416 times
Re: Foot peg lowering kit for RT
Panman40 wrote: Sun Jun 04, 2023 10:26 am Anyone suffering with lack of ground clearance with these peg lowering kits ? 🤔
I've touched down on a rbt 2-up, but no problems, other than a bit of verbal from the passenger!
Has liked: 639 times
Been liked: 110 times
Steve398 wrote: Sun Jun 04, 2023 2:50 pm I've touched down on a rbt 2-up, but no problems, other than a bit of verbal from the passenger!
:lol: , ok Steve thanks, I probably don’t have your cornering skill set so should be ok, I’m clicking on the link here but struggling to get to checkout. Is there a better link ?.
Steve398 wrote: Sun Jun 04, 2023 4:24 pm Is this the one you tried Martin?
https://m.aliexpress.com/item/100500401 ... t=Pc2Msite
That’s the one Steve but this one’s English thanks. Had difficulty signing in but sorted now. In my basket waiting for me to pull the hesitant trigger 🤣
You won't regret it matey, it really does improve the comfort.
jclaudej
Bike Model and Year: 1250 RT 2019
Has liked: 11 times
Been liked: 16 times
Contact:
France
Post by jclaudej »
After about 6000 km I never have a ground clearance problem.
Jggpossum
Has liked: 3 times
Been liked: 21 times
Australia
Post by Jggpossum »
That is the exact same kit and supplier I used, and the brake lever lowering plate fitted perfectly and the peg lowering brackets were a nice piece of kit. The only issue as I posted elsewhere is the large grub screw that helps hold the new bracket tightly in place is too long by about 5mm and has to be filed down. There are two grub screws each side and the smaller one fits perfectly. Don't let this put you off buying it.
Has liked: 1468 times
Steve398 wrote: Wed May 24, 2023 8:50 pm There has been comments in the past about the quality of Chinese pattern parts/accessories, but when I picked up my RT from service yesterday it transpired during conversation with the mechanic that he uses Aliexpress parts on his K1600 too…
Most sensible people do
Although I've only sat on the bike since I fitted the kit,I was having trouble getting contacted with the gear lever.I chanced an enlarger/extender from ebay and it seems to be a lot better.
Next Saturday is d-day,hopefully the extender will give me the extra touch :thumb:
Forgot to say,also from China :mrgreen:
I made extenders to fit brake and gear levers. I haven't over large feet(9) but i felt like i had to tuck my feet inwards to push the brake and gear levers.
Along with the peg lowing kit i no longer have knee problems after a long ride.
Jggpossum
Has liked: 3 times
Australia
Post by Jggpossum »
I just received my BMW Hight Seat which I ordered as an extra with the original bike deal. After fitting that, adding a lambskin seat cover on top, and having lowered the foot pegs already.... I finally have an ideal riding position for my 190cm/6'4" height (86.4cm/34" inseam). Of course the windscreen now is not high enough to fully protect my head from wind buffeting, but I can live with that.
Rode the bike for the1st time in 2 years today :( Turns out I can't change gear with the front of my foot,only the heel.I can't twist my ankle enough(this is after me accident last may)
Thought this extender would do the trick
But no.I have an idea I used on my GSF but before I go down that route,anybody else extendedthe gear lever.
If your gear lever is like on my 07 it's made of steel. If so just cut and insert a piece of steel with the length required
I have a sleeve idea up my erm,,,,,,,,sleeve :thumb:
Del P
Post by Del P »
I want to put a peg lowering kit on my 2013 (old shape) RT but I am struggling to find the kits now (except at extortionate prices). Everything on Aliexpress seems to be for the later model 1200 and 1250s. Does anyone know if it is possible to fit the later model kits to the earlier bike or are they totally different. The photos look similar but are not always necessarily true to the actual item. Thanks
