Disconnecting battery
Potential new owner..
Post by Potential new owner.. »
I've disconnected my battery on my new RT1250 to fit some accessories. Connected everything back up but the bike won't start. What could it be?
Re: Disconnecting battery
Have you checked everything?
Is it in neutral etc
Disconnecting the battery and reconnecting it should stop it starting.
Check your connections too
Yea checked all connections. disconnected the accessories and put it back the way it was & still won't start.
Is the bike turning over?
No. The Dash doesn't start up either.
That suggests to me that the battery is not connected properly somewhere or the main fuse is popped
Pull the battery and check the polarity and also check the main fuse
Ok, sorted..a loose connection. Rather obvious. Thanks for your reply!
Crotters
Post by Crotters »
Hi, can someone tell me where the main fuse is? I've looked online at the fuse box and can't see a "main fuse" listed. Thanks Pete
Has liked: 1433 times
no fuses. The bike uses canbus system
7vwh
Has liked: 18 times
Been liked: 40 times
Post by 7vwh »
Fuses under the rider’s seat.
well blow me :o . I always thought everything was run by the canbus. My 07 has any fuses
Totaled TL
Been liked: 9 times
Post by Totaled TL »
sakm wrote: Sun Oct 01, 2023 2:19 pm Have you checked everything?
That would stop it starting?
Totaled TL wrote: Sat Oct 14, 2023 1:42 pm That would stop it starting?
Typo from me there it should say shouldn't stop it starting!
