key not turning
- Bike Model and Year: 2012 BMW R 1200
key not turning
My BMW R1200RT is having problems with the ignition. I am having trouble turning the key. I washed the key to remove any dirt but it made no difference. What else can be done?
- EasyRider
- Has liked: 90 times
- Been liked: 167 times
Re: key not turning
Tyr some grease on the key, and work it into the lock.
Also try moving the key slowly in and out as you try to turn it.
I had one bike that when you put the key in you needed to pull it back about 3mm for it to turn.
- Been liked: 207 times
Re: key not turning
Exactly as BoB21 has said,graphite powder.DO NOT PUT GREASE DOWN THE BARREL OR ON THE KEY.Push thd tip of the key in the barrel and squeeze a little powder in/on the barrel and key and gently work the key up and down side to side.you do not need a lot of graphite powder or you will clog the barrel.
- EasyRider
Re: key not turning
I've always used white lithium grease or even WD40. But i think its each to there own. Its worked for me.
Like you have said, graphite is a powder and if you put to much in the key will compact it at the bottom as the ignition barrel is vertical.
You can also mix a small amount of graphite powder with water to make it flow better and work it in that way. The water will evaporate leaving the graphit in place.
- Has liked: 922 times
- Been liked: 245 times
Re: key not turning
Rub a pencil on both sides of the key. As good as Graphite oil. Thats what us old times used to us
Re: key not turning
Not having that,you were on the chalk n slate back in the day (Steve made me say it )
- Steve398
- Has liked: 306 times
- Been liked: 244 times
Re: key not turning
burridge01 wrote: ↑Sun Dec 10, 2023 5:31 pm Not having that,you were on the chalk n slate back in the day (Steve made me say it )
Re: key not turning
I was always getting the Berch from the Headmaster. Think he was a bit Kinky
Re: key not turning
Could be one of the little locking pins or springs inside the lock could have become misaligned
