key not turning
Paxton6754
Bike Model and Year: 2012 BMW R 1200
key not turning
Post by Paxton6754 »
My BMW R1200RT is having problems with the ignition. I am having trouble turning the key. I washed the key to remove any dirt but it made no difference. What else can be done?
Re: key not turning
Tyr some grease on the key, and work it into the lock.
Also try moving the key slowly in and out as you try to turn it.
I had one bike that when you put the key in you needed to pull it back about 3mm for it to turn.
Has liked: 226 times
Been liked: 102 times
Re: key not turning
Try Graphite oil/powder.very messy so put on key.
Re: key not turning
Exactly as BoB21 has said,graphite powder.DO NOT PUT GREASE DOWN THE BARREL OR ON THE KEY.Push thd tip of the key in the barrel and squeeze a little powder in/on the barrel and key and gently work the key up and down side to side.you do not need a lot of graphite powder or you will clog the barrel.
Re: key not turning
I've always used white lithium grease or even WD40. But i think its each to there own. Its worked for me.
Like you have said, graphite is a powder and if you put to much in the key will compact it at the bottom as the ignition barrel is vertical.
You can also mix a small amount of graphite powder with water to make it flow better and work it in that way. The water will evaporate leaving the graphit in place.
Re: key not turning
I use graphite oil as it's liquid form. Grease / WD40 will work but collect dirt and block again.we use graphite oil at work on locks for that reason.
Re: key not turning
Small puff of powder :mrgreen:
Has liked: 1433 times
Re: key not turning
Rub a pencil on both sides of the key. As good as Graphite oil. Thats what us old times used to us
Re: key not turning
Doctor T wrote: Sun Dec 10, 2023 4:04 pm Rub a pencil on both sides of the key. As good as Graphite oil. Thats what us old times used to us
Not having that,you were on the chalk n slate back in the day :lol: :lol: (Steve made me say it :o )
Has liked: 473 times
Been liked: 404 times
Re: key not turning
burridge01 wrote: Sun Dec 10, 2023 5:31 pm Not having that,you were on the chalk n slate back in the day :lol: :lol: (Steve made me say it :o )
:o :lol: :lol:
Re: key not turning
I was always getting the Berch from the Headmaster. Think he was a bit Kinky
Orion7562
Bike Model and Year: R 1200 2019
Re: key not turning
Post by Orion7562 »
Re: key not turning
Could be one of the little locking pins or springs inside the lock could have become misaligned
