Garage Door Remote Control
- Has liked: 17 times
- Been liked: 134 times
Something I've been wanting to do for a long time is to fit a press button somewhere on the fairing so when I get home I can press the bottom as I approach the garage and ride straight in. I looked at several kits, all horrendously expensive and overly complicated so I made my own! I now have a fully functional and discretely mounted garage door operator in my RT.
1a. The original remote control. As you can see it's got a large press button on the front.
1b. Opening it up shows that button is pressing onto a tiny button on a circuit board.
1c A friend soldered two wires to it for me.
1d I drilled two holes through the case, fed the wires through, sealed the holes and reassembled. At the other end of the wire goes a sprung loaded momentary push button. It works exactly the same as the main remote and the one I chose is allegedly waterproof.
2a Note O-Ring under the flange for weather proofing and the thin 'nut'.
2b Two wires, dead easy. Remove the Fairing Panel - Measure it twice, cut it once.
3a. Where I wanted to put the momentary switch was carefully measures so the new push button would be in line with and have the same centre to centre measurement as the OEM Radio buttons.
3b Unfortunately the screw holding the case the radio buttons are in was in the way.
3c So I had to move it up an inch or so.
3d Drilling the hole. That's the, right I'm committed here now moment! Installation.
4a The momentary push button needed to be pressed through hole, the wires reattached, but the nut was impossible to tighten with a spanner, so finger tight & threadloc it had to be. It shouldn't vibrate free and even if it does, as the button was tight fit and isn't going anywhere fast.
4b The original remote control was attached to a plastic mounting with a 1" square of self adhesive heavy duty Velcro. This will allow it to be easily remove when the battery needs replacing. Everything behind the fairing panel looked dry and that rain or spray doesn't get in so the original body of the remote control should be safe from the weather.
4c. The finished job. I'd have preferred the push button to be a little closer to the radio buttons, but the aforementioned screw was in the way so there's a bit of a gap. By next week I'm sure I won't even notice it. Anyway, everything works, the button is in easy reach and looked neat enough for me.
Re: Garage Door Remote Control
The actual doing bit wasn't that bad, just took a bit of courage to drill the hole! The remote was sitting unused in the spares drawer, the push button cost £8.00, the hole cutter £5.20, (both from Amazon) and the soldering & wire a beer.
Quite cheap and in the end easy to do.
- Stu
- Has liked: 619 times
- Been liked: 598 times
I have all the gear in the garage so no cost involved at all for me! Just time to actually do it!Capt Sisko wrote: ↑Wed Mar 13, 2024 9:39 pm The actual doing bit wasn't that bad, just took a bit of courage to drill the hole! The remote was sitting unused in the spares drawer, the push button cost £8.00, the hole cutter £5.20, (both from Amazon) and the soldering & wire a beer.
For the time being I stuck the remote temporarily to the underneath of one of the cubby hole lids
Been like it for 2 years
- ColoradoGreek
- Bike Model and Year: R1200RT / 2016
- Been liked: 3 times
i bought this little guy and keep it in my tank bag and it works great:
https://www.temu.com/ul/kuiper/un9.html ... DCEALw_wcB
Colorado Greek
2016 R1200RT
2016 R1200RT
- Has liked: 1433 times
- Been liked: 406 times
Snobs with all these fancy gadgets.
- EasyRider
- Has liked: 151 times
- Been liked: 364 times
Great job there Capt. I did sort of the same. I dont have a radio so used the holes that were already in the panel.
To be honest the OEM radio on my '18 is a waste of time. AM & FM only and a 3.5mm jack socket for an MP3 player. I mean who still broadcast on those frequencies or uses an ipod nowadays. Then there's the wind & engine noise, not to mention my head's inside a helmet with -27db earplugs in!
My bike was an ex demo bike and loaded with just about everything, but having tried it I wouldn't pay the extra for a radio if I was ordering a new bike.
- Stu
I'm exactly the same with mine!Capt Sisko wrote: ↑Thu Mar 14, 2024 5:04 pm To be honest the OEM radio on my '18 is a waste of time, AM & FM only and a 3.5mm jack socket for an MP3 player. I mean who still broadcast on those frequencies or uses an ipod nowadays. Then there's the wind & engine noise not to mention my head inside a helmet with -27db earplugs in.
My bike was an ex demo bike saw was loaded with just about everything, but having tried it I wouldn't pay the extra for a radio to be fitted to a new bike.
- Has liked: 1 time
- Been liked: 9 times
- Has liked: 4 times
Flash2Pass.com, mounts on the bike under a fairing or behind the speaker, the way it works is you flash your high beams coming up the drive. Bam! garage door opens! Like pulling into the "Bat Cave"
2023 R1250RT
2022 R1800TC gone
2016 R1200RT w/c gone
2014 K100GTL (gone)
2014 R1200RT w/c (gone)
2005 R1200RT Hex head (gone)
2022 R1800TC gone
2014 K100GTL (gone)
FYI - Flash2Pass have ceased trading, and the company that acquired the rights (NSDC) have discontinued them. They do have a replacement but 1/ It looks one heck of a lot more complicated. And 2/ It's $260 before I even think about shipping & import costs to the UK. My DIY system cost less than £20.00 (including a special hole cutting drill which I'll probably never use again). Ultimately it was quite cheap and a lot easier to do than I thought. It just took a bit of courage to drill into the fairing.
- Been liked: 10 times
Love this idea!
I have my somfy door remote cable ties to handlebars...I thought I was pretty smart doing that but your install is next level. Bravo!
- Glenn
- Has liked: 53 times
- Been liked: 189 times
I've just fitted mine to the bike, I removed the blanking plate and fitted a 3d printed mount/box, stl attached (credit to Boite Bouton lumineux étanche by ebraud on Thingiverse: https://www.thingiverse.com/thing:3561910) and 3 cap blanks.
- PXL_20240812_184112372.jpg (243.23 KiB) Viewed 7472 times
- Box_BPL_C.zip
- (141.79 KiB) Downloaded 272 times
