Garage Door Remote Control
Has liked: 17 times
Been liked: 134 times
Something I've been wanting to do for a long time is to fit a press button somewhere on the fairing so when I get home I can press the bottom as I approach the garage and ride straight in. I looked at several kits, all horrendously expensive and overly complicated so I made my own! I now have a fully functional and discretely mounted garage door operator in my RT.
1a. The original remote control. As you can see it's got a large press button on the front.
1b. Opening it up shows that button is pressing onto a tiny button on a circuit board.
1c A friend soldered two wires to it for me.
1d I drilled two holes through the case, fed the wires through, sealed the holes and reassembled.
1. Remote Control.jpg (367.48 KiB) Viewed 10989 times
At the other end of the wire goes a sprung loaded momentary push button. It works exactly the same as the main remote and the one I chose is allegedly waterproof.
2a Note O-Ring under the flange for weather proofing and the thin 'nut'.
2b Two wires, dead easy.
j. Momentary - Two wires.jpg (239.43 KiB) Viewed 10989 times
Remove the Fairing Panel - Measure it twice, cut it once.
3a. Where I wanted to put the momentary switch was carefully measures so the new push button would be in line with and have the same centre to centre measurement as the OEM Radio buttons.
3b Unfortunately the screw holding the case the radio buttons are in was in the way.
3c So I had to move it up an inch or so.
3d Drilling the hole. That's the, right I'm committed here now moment!
3. Drilling.jpg (256.51 KiB) Viewed 10989 times
Installation.
4a The momentary push button needed to be pressed through hole, the wires reattached, but the nut was impossible to tighten with a spanner, so finger tight & threadloc it had to be. It shouldn't vibrate free and even if it does, as the button was tight fit and isn't going anywhere fast.
4b The original remote control was attached to a plastic mounting with a 1" square of self adhesive heavy duty Velcro. This will allow it to be easily remove when the battery needs replacing. Everything behind the fairing panel looked dry and that rain or spray doesn't get in so the original body of the remote control should be safe from the weather.
4c. The finished job. I'd have preferred the push button to be a little closer to the radio buttons, but the aforementioned screw was in the way so there's a bit of a gap. By next week I'm sure I won't even notice it. Anyway, everything works, the button is in easy reach and looked neat enough for me.
4. Installtions.jpg (260.94 KiB) Viewed 10989 times
Re: Garage Door Remote Control
This is something that I also want to do!
It's just finding the time 😂
Has liked: 17 times
sakm wrote: Wed Mar 13, 2024 7:47 pm This is something that I also want to do!
The actual doing bit wasn't that bad, just took a bit of courage to drill the hole! The remote was sitting unused in the spares drawer, the push button cost £8.00, the hole cutter £5.20, (both from Amazon) and the soldering & wire a beer.
Quite cheap and in the end easy to do.
Capt Sisko wrote: Wed Mar 13, 2024 9:39 pm The actual doing bit wasn't that bad, just took a bit of courage to drill the hole! The remote was sitting unused in the spares drawer, the push button cost £8.00, the hole cutter £5.20, (both from Amazon) and the soldering & wire a beer.
I have all the gear in the garage so no cost involved at all for me! Just time to actually do it!
For the time being I stuck the remote temporarily to the underneath of one of the cubby hole lids
Been like it for 2 years :lol:
ColoradoGreek
Bike Model and Year: R1200RT / 2016
Post by ColoradoGreek »
i bought this little guy and keep it in my tank bag and it works great:
https://www.temu.com/ul/kuiper/un9.html ... DCEALw_wcB
Colorado Greek
2016 R1200RT
Has liked: 1433 times
Snobs with all these fancy gadgets. ;)
Great job there Capt. I did sort of the same. I dont have a radio so used the holes that were already in the panel.
Has liked: 17 times
EasyRider wrote: Thu Mar 14, 2024 2:12 pm I dont have a radio so .......
To be honest the OEM radio on my '18 is a waste of time. AM & FM only and a 3.5mm jack socket for an MP3 player. I mean who still broadcast on those frequencies or uses an ipod nowadays. Then there's the wind & engine noise, not to mention my head's inside a helmet with -27db earplugs in!
My bike was an ex demo bike and loaded with just about everything, but having tried it I wouldn't pay the extra for a radio if I was ordering a new bike.
Capt Sisko wrote: Thu Mar 14, 2024 5:04 pm To be honest the OEM radio on my '18 is a waste of time, AM & FM only and a 3.5mm jack socket for an MP3 player. I mean who still broadcast on those frequencies or uses an ipod nowadays. Then there's the wind & engine noise not to mention my head inside a helmet with -27db earplugs in.
My bike was an ex demo bike saw was loaded with just about everything, but having tried it I wouldn't pay the extra for a radio to be fitted to a new bike.
I'm exactly the same with mine!
Totaled TL
Been liked: 9 times
Post by Totaled TL »
Just velcro a remote inside cubby hole lid. Easy.
OscarTGrouch
Has liked: 4 times
Post by OscarTGrouch »
Flash2Pass.com, mounts on the bike under a fairing or behind the speaker, the way it works is you flash your high beams coming up the drive. Bam! garage door opens! Like pulling into the "Bat Cave" :lol:
2023 R1250RT :lol:
2022 R1800TC gone :)
2016 R1200RT w/c gone :)
2014 K100GTL (gone) :(
2014 R1200RT w/c (gone) :(
2005 R1200RT Hex head (gone) :(
Has liked: 17 times
OscarTGrouch wrote: Tue Mar 19, 2024 2:05 am Flash2Pass.com, ...............
FYI - Flash2Pass have ceased trading, and the company that acquired the rights (NSDC) have discontinued them. They do have a replacement but 1/ It looks one heck of a lot more complicated. And 2/ It's $260 before I even think about shipping & import costs to the UK. My DIY system cost less than £20.00 (including a special hole cutting drill which I'll probably never use again). Ultimately it was quite cheap and a lot easier to do than I thought. It just took a bit of courage to drill into the fairing.
Orca the RT
Been liked: 10 times
Post by Orca the RT »
Love this idea!
I have my somfy door remote cable ties to handlebars...I thought I was pretty smart doing that but your install is next level. Bravo!
Has liked: 53 times
Been liked: 189 times
I've just fitted mine to the bike, I removed the blanking plate and fitted a 3d printed mount/box, stl attached (credit to Boite Bouton lumineux étanche by ebraud on Thingiverse: https://www.thingiverse.com/thing:3561910) and 3 cap blanks.
Box_BPL_C.zip
(141.79 KiB) Downloaded 272 times
Has liked: 80 times
Been liked: 87 times
Post by Sullivj »
Nice neat job.
I phone my wife from the end of our road and she opens the garage for me!
