Intermittent TPMS
Intermittent TPMS
Just recently I have noticed that the rear TPMS is not registering a pressure
I don't get a low pressure warning just no reading
Is this a sign of a failing sensor or flat batteries?
60Aviator
Bike Model and Year: 2017 GSA & 2021 R1250RT
Has liked: 8 times
Been liked: 14 times
Re: Intermittent TPMS
Post by 60Aviator »
Battery is on its last legs.
Next question what batteries do the TPMS take?
Don't think the batteries are designed to be replaced, viewtopic.php?p=38354&hilit=tpms+battery#p38354
Schrader make a replacement, viewtopic.php?p=59978#p59978
There not but doesn't mean you can't 😉
From having a Google it seems the battery is a cr2050 although others have use different ones with good results
Has liked: 99 times
Been liked: 223 times
sakm wrote: Sun May 26, 2024 5:13 pm There not but doesn't mean you can't 😉
Easy job! Did mine with a craft knife and hot glue gun a couple of years ago. 👍
k9doc
Has liked: 7 times
Been liked: 16 times
Post by k9doc »
Don't know if it's different on the later bikes, but on my 2013 if it was the battery you get the dreaded yellow triangle plus 'RDC' message briefly on start up. If it's just -- or --/-- with the yellow triangle, then chances are it's dodgy sensor(s).
AliExpress worth a look. £10 for a pair of new ones. I was tempted for my 2013 RT if warranty hadn't covered and replaced with a 'BMW' one @ £104 + VAT. Same part #. Just had a footpeg lowering kit from them and looks just as good as the Wunderlich ones and less than a quarter of the price. Pays your money..........!
Chris
@k9doc I get no warnings on the dash just the two lines where the pressure should be as if the sensor has not started to work like when you first turn it on before you ride
k9doc
Has liked: 7 times
Post by k9doc »
sakm wrote: Sun May 26, 2024 8:18 pm @k9doc I get no warnings on the dash just the two lines where the pressure should be as if the sensor has not started to work like when you first turn it on before you ride
Beats me - no warning light.
Chris
60Aviator
Has liked: 8 times
Post by 60Aviator »
If you do a search on the other forums there is a KTM part number that is the same thing as BMW but was only $65 when I got one vs $200+ for BMW.
60Aviator wrote: Sat Jun 01, 2024 12:31 pm If you do a search on the other forums there is a KTM part number that is the same thing as BMW but was only $65 when I got one vs $200+ for BMW.
Yes found all that
Also found a place here in the UK supplying them for £60 each
Today it totally scrapped itself and showed an error then started to work again!
took the decision to buy two new TPMS
Still waiting for one to be delivered but the faulty one has been replaced and is working fine now
I went for the Schrader 3142M which is the ones for the KTM the BMW one is the 3141M but they are all the same
You also have to replace the bolts too
Has liked: 617 times
sakm wrote: Fri Jun 14, 2024 9:10 pm took the decision to buy two new TPMS
That’s useful to know Stu, so you didn’t bother messing with batteries then ?, where may I ask did you purchase the tpms from ?. I suspect my 2019’s will need replacing next year.
Also did you go to a tyre dealer to have th tyres removed , go home to fit the sensors then go back for refitting ?.
Panman40 wrote: Sat Jun 22, 2024 6:57 am That’s useful to know Stu, so you didn’t bother messing with batteries then ?, where may I ask did you purchase the tpms from ?. I suspect my 2019’s will need replacing next year.
No I couldn't be arsed to faff about with batteries! I think I'm getting too old for that crap these days 😂
I found them on ebay I ordered two but only have one at the min as the other one is on back order!
No I removed the tyre and fitted it sensor then refitted the tyre then balanced the wheel
sakm wrote: Sat Jun 22, 2024 9:10 am No I couldn't be arsed to faff about with batteries! I think I'm getting too old for that crap these days 😂
I know what you mean 🤣, oh are you on Michelins ?, they look very tight to get on and off 🤔
