Exploding shaft drives
Strat Tuner
Has liked: 156 times
Been liked: 30 times
Post by Strat Tuner »
Welcome to bmw ownership.
Watch out for exploding shaft drives!! :-)
- Willie Nelson
Strat Tuner
Re: Exploding shaft drives
Cruising today on twisty roads...
Slight vibration.. that's new,
3 miles later, worse... Do I have a flat?
A few miles more, heavy vibration, burning smell....
Pull over now!
The rubber cover on the shaft drive burned away. All shaft oil gone. Bare shaft parts exposed. No forward motion in first gear.
The dealer has it for repair.
Anyone ever replaced a shaft drive?
About how much does that run?
- Willie Nelson
Our Gee
Been liked: 33 times
Post by Our Gee »
It may not be in the BMW R1200RT service schedule but regular inspection and lube of at least the "rear" Universal Joint and Splines is advisable. There are many horror stories out there which no doubt can be attributed to the Out of Sight, Out of Mind syndrome. It's a relatively straight forward job to lower the Final Drive, check the Joint for stiffness or rough movement and clean and lube the Splines. It can be a bit fiddley re-locating the Shaft onto the Hub Splines whilst positioning the Rubber Boot but this gets easier after a few times.
Strat Tuner wrote: Sat Jan 18, 2025 9:02 pm All shaft oil gone.
There is no shaft oil
The oil is in the bevel gear housing and the shaft is run dry
If there is no damage to anything else then its a simple shaft replacement and rubber boot and you're good to go
Strat Tuner
I'll hope for that. I caught it quickly I think and hopefully minimized damage.
I won't know for three days or so.
I'll post diagnosis if anyone's interested.
Took it to a dealer not my usual independent mechanic.
When repair goes past about 5K, it's junk yard time.
- Willie Nelson
Fingers crossed it's just the shaft and as has been posted elsewhere on the forum you can buy cheaper better replacements
Strat Tuner
But would the dealer accept that? Hmmmmm...
- Willie Nelson
If you're not happy with their price you can easily take it elsewhere or supply you own parts
When I say easily it would obviously on a recovery truck
Strat Tuner
Good advice, Stu. I'm thinking of offering the work to my usual mechanic once I know what needs doing.
Thanks for the encouragement! I could use that about now. :-)
- Willie Nelson
I suppose it will all come down to the labour costs really as the shaft price is the price regardless of who you go to
The labour for your local mechanic + transport Vs BMW is what you need to be looking at
Strat Tuner
Yes, my usual guy could beat a dealer rate.
- Willie Nelson
Strat Tuner
https://www.beemershop.com/product/r120 ... lines.html
Wow. I just got brave enough to go and look there. I don't know about splines and exactly which one to order, but the price was encouraging. $800 for a new one. (656 British Pounds) Even if the labor were 500, that would put the repair in range.
I'd really like to restore and keep this BMW. It's my first one, a life-long dream bike, and I don't want it to be the last.
- Willie Nelson
Strat Tuner wrote: Sun Jan 19, 2025 10:08 pmI don't know about splines and exactly which one to order.
Looking at the BeemerShop website, https://www.beemershop.com/category/clu ... -3986.html they list two driveshafts, (20 or 22 splines).
From what I can see, 20 splines up to 12/2007 and 22 splines from 01/2008. Best check with BeemerShop before ordering.
From MAX BMW Parts list for an R1200RT 05-09.
MAX BMW.jpg (46.64 KiB) Viewed 4578 times
Strat Tuner
David. wrote: Mon Jan 20, 2025 11:50 am Looking at the BeemerShop website, https://www.beemershop.com/category/clu ... -3986.html they list two driveshafts, (20 or 22 splines).
I sent the following:
Dear BeemerShop, My shaft drive failed this week. I'd like to order a replacement. I don't know if i need 20 splines or 22. The R1200RT is 2008 (I think), and the VIN is ---------------------------.
Please advise. Thank you in advance.
Of course, I sent the actual VIN, but I kept it short and to the point.
Should be fun to watch this story unfold.
- Willie Nelson
