Timing Cover - Screws & Washers
I'd like to replace the original (now corroded after 3 years) Timing Cover Screws & Washers on my 2012 Twin Cam RT.
The BMW Part No. is 07 12 9 905 537 & they cost £2.33 each x 12 = £27.96.
A trip to Hawk Fasteners in Middlesbrough came up with some Stainless Steel M6 x 30 Socket Head Cap Screws & Washers (12 off) for £6.21.
If you have changed any screws or fixings etc. for Stainless Steel, where did you get them from, thanks.
stelyn
Re: Timing Cover - Screws & Washers
Post by stelyn »
David, I did the same as you changed the existing ones with stainless steel bolts which are easy to `undo' , got mine  at Screwfix, ....... ;)
stelyn
Post by stelyn »
Complete Sets by Bristol Super Bikes,  £9.99  see Link;    :whistle:
  http://www.ebay.co.uk/itm/BMW-R1200GS-R ... 27fcfe4934
Cheers Steve, the Allen Headed Screws with separate Washers look the same as the ones I have already purchased.
The smaller Screws in the ebay link will be for the plastic Alternator Belt Cover & Beltguard, M5 x 16 (7 off).
Bought (7 off) M5 x 16 Stainless Steel Screws today for £1.
Removed one of each M5 x 16 & M6 x 30 Bolts to check the sizes including the Washers, they fit perfectly.
Better quality than BMW OE at a fraction of the cost.
stelyn
Post by stelyn »
£1  -  That's even cheaper, where did you get them ?      ;)
Teesside Industrial Fasteners, http://www.tsidefasteners.co.uk/.
The BMW OE M5 x 16 Screws cost $0.96 each, (approx. £0.64).
Steveeung
Post by Steveeung »
Couple of questions... Does anyone know where you can get these for the LC (stock ones are cheap looking)? Also what torque setting should they be tightened to?
RT LE, San Marino Blue, Cee Bailey Screen, Nav IV, Hornig horn, Aux Lights, Michelin Pilot Road 4GT, Crud Deflector, Fender Ext
Looks like this is the Front cover / oil tank on an LC, http://www.realoem.com/bmw/showparts.do ... g=11&fg=14.
The Screws are M6 x 20mm (16 off), available from Amazon, http://www.amazon.co.uk/Socket-Bolts-St ... B00A76IKCC.
Don't forget the Washers, http://www.amazon.co.uk/Washer-Stainles ... DWMCCRZG7J.
The Torque setting on a Twin Cam is 9Nm, (Bolt size is M6 x 30mm).
It's worth noting that A2 Stainless Steel is not the same grade or quality as A4, but still better than BMW OE.
I was initially offered some A2 Screws but the finish on the heads was poor, (could have been a faulty batch).
The guy in the store suggested using A4 at twice the cost.
Looks like to complete the job on a Twin Cam, you need some screws for the two Fairing Brackets which bolt to the Stud Bolts on the Timing Cover.
http://www.realoem.com/bmw/showparts.do ... g=46&fg=63
Item No. 03, Screw & Washer M6 x 45mm (1 off), plus Item No. 06, Oval-head Screw M6 x 16mm (2 off).
