Garmin express 4.3.0.0 update now available
Re: Garmin express 4.2.0.0 update now available
Downloaded and installed in around 2mins  :)
Which one. 2 or 3
Been liked: 480 times
Benchmark wrote:Downloaded and installed in around 2mins
Thanks, will do it after the map update is complete, don't hold your breath, still showing 4 hours 10 minutes.
guest3074
Post by guest3074 »
Which one. 2 or 3
4.3.0.0
I've tried it another couple of times but it fails about half way through.  Obviously doesn't like Derbyshire.
Peter Baker
Has liked: 14 times
Been liked: 7 times
Post by Peter Baker »
If you are just doing the 3.4 Navigator software should be quick, if you have to do the 7GB of Maps it could be longer:-) Peter
Stopped map update, it seemed to be taking forever.
Installed Garmin Express update to 4.3.0.0.
Restarted map update, time remaining now showing 1 hour 15 minutes & blue indicator bar is moving.
stayingupright
Re: Garmin express 4.3.0.0 update now available
Post by stayingupright »
You can update just the maps you want to update.
I bet you are installing all the maps. You may not want to install the foreign maps for instance just now. (you can still install them another time if you want to).
The more maps you install now the more chance it will need to put some of them onto your memory card in your Garmin.
Last edited by stayingupright on Fri Nov 11, 2016 11:04 am, edited 1 time in total.
stayingupright wrote:I bet you are installing all the maps.
Good point, however, with probably only two updates per year, last done in May 2016, I just do the lot.
The 3D maps seem to be installed on the device, whilst the full coverage goes on the memory card.
I'm updating the PC & device at the same time.
Less than 1 hour to go, will keep you posted.
All done, PC (BaseCamp & MapSource) plus device (660) now up to date.
Full coverage of Europe 2017.20 plus 3D maps & Garmin Express Version 4.3.0.0 installed.
Peter Baker
Has liked: 14 times
Been liked: 7 times
Re: "You can update just the maps you want to update." I don't believe you can with Garmin Express unlike TomTom and as David says 90 min every 6 months or so is not the end of the world (he said having recently got upgraded from 1MB to 26MB broadband!)
Plus I realise I posted the wrong image above, you can update Garmin Basecamp without connecting/updating your Device/Map, look under the Garmin Basecamp settings you can see if an update is needed.
Peter
Express update problem solved.  Uninstalled then re installed.
Sleuth
Post by Sleuth »
Thanks for the heads up.
It did not notify me, however when I checked in the "About"  I could see the update.
It took only a few seconds (fast internet!)
Best regards
Sleuth
Best regards, Sleuth
