Downloaded and installed in around 2mins
Which one. 2 or 3
Thanks, will do it after the map update is complete, don't hold your breath, still showing 4 hours 10 minutes.Benchmark wrote:Downloaded and installed in around 2mins
4.3.0.0RTman10 wrote:
Downloaded and installed in around 2mins ![]()
Which one. 2 or 3
Good point, however, with probably only two updates per year, last done in May 2016, I just do the lot.stayingupright wrote:I bet you are installing all the maps.
The more maps you install now the more chance it will need to put some of them onto your memory card in your Garmin.
